Car lift problem
   / Car lift problem #71
You can test the relief valve by topping out the lift and see if the motor stalls or system goes into relief.
Yeah a pressure gauge can be found locally pretty easy
   / Car lift problem
I think if it had a mechanical issue the pump would run against the pressure relief. That is assuming the pressure relief works and set to the correct pressure. But you never know.
I think a pressure gauge would be a good investment rather than throwing parts at it. Surplus center has them cheap.
i know i could really use one.
   / Car lift problem #73
So the next time you go out there, create the stall situation again, then pull the lower lever right after to see if it will start. This would releive the pressure as it is trying to start.
Can you explain how you tested the capacitor?
So tonight, I went to my dad's to plow the snow. I get there, and the house is cold. Furnace not running, the fan motor blew the breaker and would not start and kept tripping the breaker. He has an old big house with a 7,000 CFM blower and a 220V 3HP motor. I replaced it last year since it was acting up and blowing the breaker even with a new capacitor. So today, the capacitor was dead, and I did have a spare, so swapped it out and started right up. I have a digital capacitor tester, and it shows it is dead.
But, it sounds just like your issue. I think you have a motor issue or the pump is jamming somehow. If you had a bad hose or cylinder, you would still get some movement but slow especially since you can raise and lower it without a load. For it not to start at all I think it points to the pump or motor.
I agree, it sounds like a bad capacitor, but the OP has tried a new capacitor and had the motor tested. I assume the motor has one start/run capacitor and no internal switch.The motor is drawing 11 amps @ 230 volt, so it takes in 2500 Watt. This energy is delivered to the shaft at about 3 HP. If it is not delivered at the shaft it is converted to heat and the motor would get very hot very fast. The pump is running with no or low load. Could a load get it jammed? I think a hydraulic restriction or a mechanical problem.
   / Car lift problem
I agree, i will test the hose tomorrow. and the pressure relief valve.
   / Car lift problem #75
I took the motor in to a shop they replaced the start switch to the capacitor, i have tested the capacitor multiple times, even had it professionally tested. if its the motor its going through their front window.:shocked:
If the motor has an internal switch, it should have more than one capacitor or not? My understanding is that the start capacitor is switched off when the motor is up speed, but the run capacitor is on all the time. Do you hear a click when the RPM's drop when the motor stops?
I am very familiar with European electrical motors, but I have limited experience with switched capacitors like in North American motors, although the basics are the same.
   / Car lift problem
I originally tested the start capacitor switch contacts by spark testing the capacitor on start up. which was determined to be bad. i had it replaced. hopefully i do not have to throw it through the front window. lol
   / Car lift problem #77
I looked again at your pictures. There seem to be 2 capacitors. One start and one run. Start capacitors should not be engaged longer than a few seconds. The start capacitor might be defective by now, after the failed start attempts. Testing a capacitor by short circuit can damage it.
I think that the motor is trying to start on the run capacitor, but this gives not enough torque to run the load.
Get a new start capacitor, and listen if the centrifugal switch turns on and off. Try this with the "lower" valve open, so the motor does run for sure. It is usually the easiest to hear when the motor is shut off and rpm's go down. If this seams OK than try normally.
What is the FLA on the motor plate?
If the motor starts up with no load and than keeps running with load added, and not starting under load, that would be indicative of a start capacitor problem.
   / Car lift problem #78
Yeah, I'm voting start capacitor. That's why I wondered if the shop tested the motor under load. I'm guessing not. If it turns out to be the start capacitor I will be disappointed in the shop for not figuring that out.
   / Car lift problem #79
Is there a check valve on the base of the cylinder as well as one on the pump? If so, would suspect that the check valve on the cylinder is leaking by and putting pressure on the pump check valve.
Aaron Z
   / Car lift problem #80
did you find the problem i have same lift no problems yet
8ft Fork Extensions (A55787)
8ft Fork...
(2) LITHONIA LIGHTING LUMINAIRE FITTING LIGHTS (A54757)
(2) LITHONIA...
2009 Peterbilt 384 T/A Wet Kit Day Cab Truck Tactor (A55788)
2009 Peterbilt 384...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2013 C&M TRAILER MFG. 14 ENCLOSED T/A CARGO TRAILER (A55745)
2013 C&M TRAILER...
