carryall use
/ carryall use #21
Northland said:
Very Nice DAP & JC-Jetro!
I just bought a TSC Farm Force carry-all for much the same purposes.
Are those 2x6's you have bolted on?
Yes they are .... pressure treated 2 x 6 with hot dip carriage bolts.
/ carryall use #22
I did the same, bolted some old treated 2x6, and now I take it with me almost everywhere. Installed a couple of tie rings, wrapped on a bit of rope and chain. Saves me lots of trips back to the barn.
/ carryall use
With all these ideas I think I'm going to build a preasure treated 4x4' box and screw it to a pallet so I can pick it up when ever I want to move veggies or any thing. then if the pallet rots away, just screw it to another one. they are free!!
/ carryall use #24
PatC said:
Went to buy a carryall at lunch today and the dealer had a king cutter carryall for $100 or a KK pallet carrier for $240. Said he would drill 4 holes in my pallet forks and it would be an effective carryall with the ability to also carry pallets, such as grass at my sons new yard.
Anyone else gone this route and opted for pallet forks rather than carryall?
I have a TC24DA with front wheel drive and front bucket.
Thanks,
You do know that a pallet of sod weighs approx. 1800 and even more when wet.(45-50 yard pallets)
/ carryall use #25
That's what I thought I would do as well. I brought home four pallets, two of them smaller, from work. This weekend I will use deck screws and my impact driver to put a box on the best sized pallet.
/ carryall use #26
Thanks,
I had looked at the pallet mover and the carry-all at the local TSC but I thought the pallet larger and heavier then what I would need so i boght the carry-all. That and there were no holes drilled in he pallet mover and it cost twice as much
/ carryall use #27
Northland,
I used some old pressure 2x10 after I salvaged them. They perfactly span the top and bopttom using 3 boards for the floor and the back. The board were in service for 20 years and shrunk about 1/2" to 3/4". I assigned them new duty for another 20 years.:D
JC
/ carryall use #28
I did not know what it would weigh but was hoping that I would be able to move at least half a pallet and if your weight is a good estimate I should be able to move at least a 1/2 pallet of grass. You can usually get the people to move them close to where you need most of grass when they deliver the pallets without tearing up everything so if tractor can move the rest closer to final resting spot, so be it.
Thanks for the weight info.
/ carryall use #29
JC-jetro said:
Northland,
JC
Good for you JC. I love it-nothing more satisfying, and smarter, then recycling materials. RRR
/ carryall use #30
Bolted a half sheet of 3/4" plywood, and a couple of office chairs to mine. Tote two old women and a couple of berry baskets to the fartherest briar patch.
/ carryall use #31
I just picked one up at TSC yesterday. They have their new supply of Farm Force implements, but had one old rusty King Kutter carryall. I compared the 2 brands, and KK is a beast compared to the new stuff. KK is rated for 1000lbs, while Farm Force is 500lbs. KK uses much heavier and wider angle iron. Botht were the same price so I bought the KK. TSC through in a couple cans of paint to cover the rust.
I plan to use it to carry a 55 gallon plastic drum to water trees, and to carry my 25 gallon 12volt sprayer with boom. After seeing some of these great ideas, I will be using it more than I thought.
/ carryall use #32
I built my own rear carry forks years ago for my Ford 1210.
They got so much use, I ended up building another set of them.
I didn't have an FEL with that tractor, so the rear forks did all the heavy lifting.
Uses:
-Go get yourself 5 or 10 pallets, as you can "palletize" a lot of tools, like Generators and such. I had a generator with air compressor screwed to a pallet, I could get AC power and compressed air to anywhere the tractor could get to.
- I stacked my firewood on pallets, then during woodstove season, it was as easy as picking up a pallet of seasoned split firewood, and setting it by the back door. When that was used, fork-up the empty pallet and bring a fresh one.
-Speaking of firewood, I would cut approx. 5 foot long logs, and haul them with the rear forks to a better suited place to be cut and split.
-Any large deliveries can be moved with ease, washing machine, dryer, freezer...etc. In my new home I moved my Jotul woodstove all the way to the threshold of the basement door. Everyone knows how heavy woodstoves can be, it made moving it childs play.
I would say that the Carry-all is an overlooked and under-appreciated attachment, I found, for years, without having and FEL, that it became
the default attachment that stayed hooked up.
Oh, lastly, we bolted a 6' by 8' piece of chain link fencing to it and dragged local baseball fields for grooming purposes.
/ carryall use #33
I bought the Farm Force/Tarter Gate carry-all. The TSC site suggest that it is good for 1000 lbs Tractor Supply Company - CARRY ALL The tag on the carry-all I bought is SKU 2128210. They didn't have any KK carry-alls to compare with though.
/ carryall use #34
A buddy of mine makes deer/turkey hunting blinds using the carry-all as the base for the blind. He bolts the blind to it, and moves them around as he sees fit. They are very sturdy, and comfortable, as weight is not an issue.
/ carryall use #35
Northland:
The TSC carryall looks just like my 1,000# rated King Kutter. The TSC is probably from the same factory as the KK; but with TSC paint and labels.
As long as it works, that's the main thing.
/ carryall use #36
generator + compressor + carryall means power and air where ever needed. Use it for the pictured t-post driver, and for elect pole saw for trimming trees , and for general hauling and cleanup. handy little gadget.
/ carryall use #37
The TSC site shows the picture of the KK. The Farm force that I saw had a FF sticker with the 500# rating on the sticker. The 2 cross pieces on the KK are welded so both flats of the angle are 45 degrees to the uprights, if that makes sense (from the end the cross piece looks like a '<'). The FF cross pieces are perpedicular (from the end the cross piece looks like a 'L'). Difficult to explain but the KK had more welded surfaces that way. The KK was also built with 3" angle iron. My KK had the same SKU #2128210, as did the other Farm force brand carryalls on display. Anyway, just be careful before buying something from TSC unless you look at the item close, since they are selling more than one design under the same SKU.
/ carryall use #38
Thanks for the follow-up Ford 850. I went out and measured my Farm Force by Tartergate carry-all. It's also made of 3" angle iron. It doesn't have a 500 sticker on it. Just says "Farm Force by Tartergate" and "Powder Coated"
Tatergate's web site shows a smaller dimension carry-all with a 500 lb capacity. American Farmland - 3 - Point Carry All - By Tarter Gate
I e-mailed tartergate and requested clarifcation. I will also call the TSC 3 pt product mgr/buyer in Nashville and ask him. I don't want a 500 lb capacity carry-all as I am sure to break it within a few months. I am going to pick up very big maple logs and I also want to use it for ballast with my FEL and grappe combo.
I'll let you know what I hear back.
/ carryall use #39
If yours is 3" angle, it is probably rated at 1000#. The FF I saw was either 2" or 2 1/2" angle iron. Much lighter weight. Light enough that when I walked over to pick one out I thought "oh crap that will never hold up for how Iwill use it". Then I saw the older KK sitting behind them. I've read on here before that TSC is getting FF from 2 different suppliers now, but I'm disappointed they are mixing the grades for the same price. Maybe my TSC has the FF priced wrong. $117 for a 500 rating seems like too much.
/ carryall use #40
Farm Force (Hawkline / Tarter / or who knows manufacturing) makes/sells a 500# unit and a 1000# unit.
Carry All Page
I'm sure it depends on what TSC is carrying at the time wether they have both in stock or just one.
Mark
