Case JX75T vs New Holland TD80 which one to buy?
   / Case JX75T vs New Holland TD80 which one to buy? #1
Tomtomy
John deere 2305
   / Case JX75T vs New Holland TD80 which one to buy? #2
That's easy, which one has the best dealer, and maybe even the better price.
SR
Do you
SR
Do you mean I don't have to worry about performance and specifications?
   / Case JX75T vs New Holland TD80 which one to buy? #4
You always have to worry about Spec. and Perf.. The Maint. and repairs, Parts etc. availability in your location. Either doesn't have as many as your Deere.
   / Case JX75T vs New Holland TD80 which one to buy? #5
To general a question. Depends on what are the main uses you are going to use the tractor for ? Maybe add some of that info, and you might get better answers.
   / Case JX75T vs New Holland TD80 which one to buy? #6
I'm not familiar with either model, but isn't Case and New Holland the same thing, just different paint and trim?
If the HP is the same, and the drivetrain is the same, then one isn't better than the other.
I know that in other Case models, the C version is a lot better than the A version, but it's a lot more money too.
Given the two choices, I would buy the one with the best Parts and Service Department close to me.
   / Case JX75T vs New Holland TD80 which one to buy? #7
Not so much with those two tractors, as for what they will do, they just aren't that far apart.
SR
Thanks guys, Case 75hp, NH 80hp, not a big change really. I go for the dealer close to me.
   / Case JX75T vs New Holland TD80 which one to buy? #9
Do they both use DEF? I bought a 70 hp tractor because I didn't want DEF. I originally wanted 80 hp so I could pull a 15 foot batwing, but it wasn't all that hard to talk myself into a 12 foot batwing to avoid DEF.
   / Case JX75T vs New Holland TD80 which one to buy? #10
Do both have: wet clutch, power reverser and power shift (full or partial)?
Those would be some important things for me.
One other is speed in specific ranges. An example is if you’re mowing at say 4mph in the lowest speed gear in a range and you have to downshift you likely will have to stop (not a issue with a full power shift/CVT) to shift ranges.
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
Unused SDLWC Wood Chipper (A55272)
Unused SDLWC Wood...
PALLET OF MISC CARQUEST PARTS (A58376)
PALLET OF MISC...
UNUSED FUTURE HWG44 HYD MINI HOLLOW WOOD GRABBER (A58376)
UNUSED FUTURE...
2024 RAM 3500 CAB & CHASSIS (A59575)
2024 RAM 3500 CAB...
2014 Case SR210 Rubber Tire Skid Steer, S/N NEM481428, PIN# JAFSR210AEM481428, Turbo Diesel Engine, (A59076)
2014 Case SR210...
