Cat. 1 PTO output shaft profile.
   / Cat. 1 PTO output shaft profile. #1
ChuckT
Central Florida
Yanmar YM1510D
IIs there a significant difference between the profile cut on a Kubota tractor PTO output stub-shaft and others?
I have a Walterscheid PTO shaft that will fit on and release from a brand new Kubota tractor but will fit but NOT release when I use it on our Yanmar. Perhaps I've misunderstood but I thought Cat.1 on an ABC tractor was identical to Cat.1 on an XYZ tractor.
TIA
cvt
   / Cat. 1 PTO output shaft profile. #2
I didn't think Cat. I had anything to do with the PTO.
I thought it only had to do with the size and hole diam. of the lift arms of the 3pt.
   / Cat. 1 PTO output shaft profile. #3
Pto shaft on your Kubota is a 1 3/8" by 6 spline. Pto shafts also come in an 1 1/8 diameter and a 1 3/8 21 spline. The latter is commonly used on 1000rpm implements. If shaft diameter and spline count are the same on both, I would look for a burr on the output shaft of the Yanmar.
7ft Pull-Behind Rake Tractor Attachment (A59228)
7ft Pull-Behind...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
Woods 18ft Batwing Rotary Cutter (A56438)
Woods 18ft Batwing...
2017 KOMATSU PC360LC-11 EXCAVATOR (A60429)
2017 KOMATSU...
Case-IH 180 Magnum (A57148)
Case-IH 180 Magnum...
1993 Ingersoll Rand 185 S/A Towable Air Compressor (A55973)
1993 Ingersoll...
