Cat 1 v/s 2 for diy
   / Cat 1 v/s 2 for diy #1
Bansil
State Of Franklin
1967 Ford 5000 w/FEL(sold), 1950 Farmall Super A for the wife to drive around (needs fixed) 2024 Kubota B2601 FEL & BH
I can run 2 and 1, tractor came with a couple cat 1 drawbars (like TSC sells)
What tounge type weight, pull weights is typical limits of them? Basically shearing off ends.
Plan on making 2" rec hitch this weekend, for under 6000 lbs vehicle's etc, should be fine
Other project is a 850/1000 pound ballast weight 3 pt setup...
Should i step up to the bigger cat 2 drawbar?
Plan is concrete barrel
Tia
   / Cat 1 v/s 2 for diy #2
I can't answer your specific question, however this diagram may help in your calculations:
Thanks for the picture, I was curious if stepping up to a class 2 draw bar would be significantly stronger for a ballast wt box over a class 1, with a 1/4" dia difference in OD?
Most charts have about 21k for generic pin shear for 7/8 dia and 31k for 1-1/8 dia
   / Cat 1 v/s 2 for diy #4
Most of the ballast box threads that are on here used cat 1, with no reported breakage. :thumbsup:
   / Cat 1 v/s 2 for diy #5
FWIW I broke the pins off of mine with 1700lbs of concrete. Granted I was using bushings to get to a cat 2.
Thanks guys! I feel better now and actually have most of my pcs cut, drilled for some fabbing this weekend!
2012 Chevrolet Colorado Ext. Cab Pickup Truck (A55852)
2012 Chevrolet...
2015 Chevrolet Tahoe SUV (A55853)
2015 Chevrolet...
2017 Ford Explorer AWD SUV (A55853)
2017 Ford Explorer...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
2001 J ODell 16ft Enclosed T/A Trailer (A51691)
2001 J ODell 16ft...
2012 OVERLAN KILL TRAILER (A53843)
2012 OVERLAN KILL...
