Cat 1 v/s 2 for diy
   / Cat 1 v/s 2 for diy #1
Bansil
State Of Franklin
1967 Ford 5000 w/FEL(sold), 1950 Farmall Super A for the wife to drive around (needs fixed) 2024 Kubota B2601 FEL & BH
I can run 2 and 1, tractor came with a couple cat 1 drawbars (like TSC sells)
What tounge type weight, pull weights is typical limits of them? Basically shearing off ends.
Plan on making 2" rec hitch this weekend, for under 6000 lbs vehicle's etc, should be fine
Other project is a 850/1000 pound ballast weight 3 pt setup...
Should i step up to the bigger cat 2 drawbar?
Plan is concrete barrel
Tia
   / Cat 1 v/s 2 for diy #2
I can't answer your specific question, however this diagram may help in your calculations:
Thanks for the picture, I was curious if stepping up to a class 2 draw bar would be significantly stronger for a ballast wt box over a class 1, with a 1/4" dia difference in OD?
Most charts have about 21k for generic pin shear for 7/8 dia and 31k for 1-1/8 dia
   / Cat 1 v/s 2 for diy #4
Most of the ballast box threads that are on here used cat 1, with no reported breakage. :thumbsup:
   / Cat 1 v/s 2 for diy #5
FWIW I broke the pins off of mine with 1700lbs of concrete. Granted I was using bushings to get to a cat 2.
Thanks guys! I feel better now and actually have most of my pcs cut, drilled for some fabbing this weekend!
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
2025 Star EV Capella Low Speed Electric Cart (A55853)
2025 Star EV...
2005 Ford F-150 Pickup Truck (A54814)
2005 Ford F-150...
2005 Military Trailer (A53424)
2005 Military...
2013 Cadillac SRX (A50324)
2013 Cadillac SRX...
Hose Reel (A53424)
Hose Reel (A53424)
