Cattail Killer, or how to clean up around the pond?
   / Cattail Killer, or how to clean up around the pond? #41
At risk of posting the most simplistic comment in this thread....we pull cattails by hand and it works well.
:D
   / Cattail Killer, or how to clean up around the pond? #42
WarrenF,
It would help if you would read my posts :p
Dave.
OOOPPPPSSSSS....sorry!!! I hit the quote button on your post and meant to hit it on anothers post. I am appropriately beating myself about the head, neck and shoulders.
The information I provided is still relevant for those who suggest that DDT does not eradicate Malaria, and its use does and IS saving little children's lives.
   / Cattail Killer, or how to clean up around the pond? #43
Dave: I would buy that eutrophication is a natural process and that humans are part of the natural system.
   / Cattail Killer, or how to clean up around the pond? #45
Cattails from what I've read and experienced will grow in water up to 3-4'. They can also grow in deeper water as long as they have a run connecting them to shallow waters. Cattails are actually very good for filtering ponds but like anything else moderation is the answer. I have solved my problem to were I WANT it, with some manual labor. Once I took care of the main issue{cattails ignored and over running} they have not been a big issue at all. No matter what form one uses to get rid of cattails they will still need to keep up with it. Cattails just don't disappear and never return, even with chemical treatment.
The pond in question is new to me not sure what a septic pond is{I'll need to look it up}. Seems like weeds would be a huge problem in septic water even with chemicals.
Something else that I have heard that works is lining the edges with lime stone. Do a search it is interesting and IMO looks very nice when done correct. They bring in a lime truck and it spreads the rocks around the edge of the pond with a shoot. Not sure what the cost would be? Around here I believe it would be more that what I'd want to spend.
WarrenF; I'll say this one last time. I don't doubt that DDT did help SOME in the stopping of Malaria. You made it sound like DDT was the only reason deaths dropped 30%. My point is,.,.,. that is wrong, there are many factors at work in the resent years to stop Malaria. There are simple things that have even helped like screen netting for sleeping. Then there are other drugs medical findings etc... that have been introduced. DDT may have it's uses {not my true feelings thoug} but I feel anytime a chemical is used it should have LOOOOONNNNGGGG term studies done. When DDT was introduced there were minimal studies done if any. It has also been proven to cause nasty things to the enviroment, fish plants birds and even animals{including humans}. I also disagree that we need chemicals to grow food, you'd be surprised at how far a little horse poo and good dirt will go :).
   / Cattail Killer, or how to clean up around the pond? #46
Here is a receipe for organic weed killer that will not harm your fish or lake or pond but will kill your weeds. I have had a lake now for 35 yrs. and have had to deal with about every problem imagineable. Be careful with Round Up around your pond or lake...it will kill fish..read the lable it was not designed to be used in ponds. If you decide to use it around the shore of your pond...do it on a day with no wind and do it from the boat spraying the round up to the shore instead of spraying from the shore into your pond. Once round up is on the plant and dries you should be OK since it is designed to adhere to the vegetation but it is the overspray that could get in your pond or lake that would do the damage...Here is the mix for the organic weed killer..
1 gal Vinegar
1 Lb. Salt
2 Tablespoons liquid Dish Soap
Mix all this together and dislove salt in warm vinegar to be sure it disolves and then add the dish soap and use a hand sprayer..good luck.
   / Cattail Killer, or how to clean up around the pond? #47
1 gal Vinegar
1 Lb. Salt
Thanks for the recipe Brin. I will try it out this Summer. I will write it on the July calendar page, at least I will eventually find it :D
Dave.
   / Cattail Killer, or how to clean up around the pond? #48
Ah, but humans do things nature cannot. They are a part of nature and so much more. Industrial and chemical processes, modern agriculture, fuels; are all things that cannot happen without people.
Dave.
   / Cattail Killer, or how to clean up around the pond? #50
I sort of felt you were beating me around the head for something I already acknowledged.
Yes, I like information. Always good to read other's points of view. Those people in Africa have their backs against the wall in so many ways all around the continent.
I have to agree with 20-20 there are other ways being or could be used to combat malaria, but the situation in Africa is a sad one. They don't have the wherewithall to address their problems in any other way. I do believe they will pay an environmental price for that too. As one person in the article put it, there has to be some stop gap solution until they can find and finance better ones.
Dave.
   / Cattail Killer, or how to clean up around the pond? #51
:D
Simple is good JimmyJ. :) Cattails are certainly more tenacious in some areas than others. In my area, it can take a long time for them to become well established and the plants are not so robust. Maybe your place is like that too.
Where I grew up in NW Ohio, it was a different story. Agriculture in that area depends on man-made drainage and tile installations under fields. Cattails in ditches were like Public Enemy #1. They would spread quickly and grow vigorously. I could argue they were well fed by farm runoff.
Dave.
   / Cattail Killer, or how to clean up around the pond? #52
o2batsea, I found a SITE that has a little information about the management and control of cattails. There might be somethings in there that gives you an idea or two of what might work. Good luck with them! :)
   / Cattail Killer, or how to clean up around the pond? #53
1 gal Vinegar
1 Lb. Salt
Another thankyou
   / Cattail Killer, or how to clean up around the pond? #54
I'm not condoning the use of DDT by any means, but from what I've heard all my life is that DDT wiped out the widespread bed bug population. The old timers were grateful for it.
Bed bugs were so widespread that if you managed to get rid of them in your house, it would only be a matter of time before they would be back. Bed bugs are voracious blood suckers and always looking for a meal.
When I was a kid, my folks and other older people used to tell the stories about how horrible bed bugs were. They said when the bed bugs bit you it would be a sharp pain and would draw blood. They would hide in the walls and crevices during the day and would come out at night.
They would tell about having to set the bed legs in a cup partially filled with kerosene to keep them from crawling into bed and biting them at night. And even after doing that, they would sometimes still get in the bed and bite you in the middle of the night.
Now, apparently from news reports, bed bugs are beginning to make a comeback in areas of the US.
   / Cattail Killer, or how to clean up around the pond? #55
BRIN :Thanks for the vinegar recipe. I too will try it next summer. I have had a terrible problem with cattails. I enjoyed them at first, then as they increased I went in and pulled many by hand, but they soon took over my pond and in a few short years had completely,..."completely" packed it, overrun every square inch,...deep, thick and 12 feet high.
Summer of 2007, during the drought in southern Ontario, Canada,..my pond, for the most part, dried up. I was able to get in with my tractor and although they were the worst things to get out,...(almost gave up and switched to chemicals), "almost" but continued withOUT chemicals,...(till much later).
My JD-3520-Cab with 73" HD bucket and tooth-bar and box-blade with scarifiers I eventually "dug" them out with their black "stinkin" muck. Never fought anything as tough as well rooted cattails!!!!
Got 'em out, dug deeper and wider and considerably enlarged my lake,(pond),..THEN did what I should have done years ago,..... I plastered my pond walls with thick wet CLAY and waterproofed my original "topsoil-etc-walls, levee etc" and in the following spring of 2008 when it filled up to the "full" mark, it was beautiful.
However as summer wore on, the darn things began to poke up through the surface again.
A local pond-supply guy who has gorgeous ponds, suggested spraying a little round-up carefully from my boat, just on whatever is above the surface. I did that everytime I noticed one and was extremely careful with it. Never saw another cattail,...... . . . till late in the summer last past to wit: 2009,...and by late fall there was quite a growth around the main inlet,..field run-off which I'll take care of in the spring. I hate to say it as much as use it,..but if Brin's Vinegar Recipe fails me,... I will use Round-up,..(carefully) (if that is possible?) but the water is deep at that point and I'm past the point (age) to get in and pull 'em by hand and can't get near 'em with the tractor. (Unless I build a "Long-Reach" bucket affair)?
WHOOOOOPS !! ...didn't mean to ramble,...just wanted to say thanks to Brin for the recipe and let you know I'll try it and try to remember to do a follow-up report on the results. Thanks again Brin.
CHEERS! ...Merry Christmas all !!
. . tug
   / Cattail Killer, or how to clean up around the pond? #56
tug.
You are quite welcome, good luck killing those cattails and any other pond weeds and grasses you do not want. The thing about this mixture is it is cheap so make as many applications as you find necessary without having to worry about harming your fish. Like with any application, you have to stay after it ..the soap in the mixture causes the salt and vinegar to adhere to the plant and it dies....please do report back..
Cheers and Merry Christmas to you and all
   / Cattail Killer, or how to clean up around the pond? #57
For further illumination, the EPA has label guidelines that establish a hierarchey to the relative hazards of products. In order of severity from lowest to highest: Caution, Warning, Danger. CAUTION-41% glysophate(Roundup including surfactants) & 5% acetic acid(vinegar)
DANGER- Sodium chloride
WARNING- gasoline
In regards to cost, I pay $67 for 2 1/2 gallons of 41% glysophate. At 2 oz/gal. of water my cost is 42 cents per gallon of spray mixture. I doubt the spray mixture of soap, salt and vinegar is any cheaper. By the way, acetic acid & sodium chloride are chemicals.
   / Cattail Killer, or how to clean up around the pond? #58
WARNING- gasoline
I think the issue may be people would probably not care for glysophate pickles. On the other hand, most like dill pickles - which are soaked/cured in vinegar and salt solutions. :D I wouldn't care for a glysophate-based BBQ sauce either, but plenty have vinegar in them. I know acetic acid and salt can kill things in high enough concentrations, so can oxygen. But there is a perspective to keep.
I see your point Forrester2. But I would still prefer to try something with known 'friendlier' chemicals before reaching for the Roundup. Without a good reason, such as raising fish for commercial purposes or the like and cattails are costing you income, I would tolerate quite a few cattails in any case.
Dave.
   / Cattail Killer, or how to clean up around the pond? #59
Friendlier?? Vinegar has a ph of 2.2. Salt water incursion threatens western aquifiers. Roundup has been studied to death for years looking for a way to vilify it.
It's not made to produce pickles, so your point is ludicrous Dave; neither is soap or cheese or cardboard for that matter.
My point is study the relative toxicity of natural and other common day to day products you use before condemning the usage of a pesticide or herbicide that does a far superior job.
   / Cattail Killer, or how to clean up around the pond? #60
We have a growing (sorry) problem with cattails spreading into the waterfront area of the Girl Scout camp where I'm the Ranger.
One of the old camp rangers visited last summer and he told me that he was able to control them and other aquatic weeds by using a trash pump to suck the soil out from around the roots and let them float free. Most of the "soil" around the roots is what I consider as muck and not what I want where the girls swim. I'm going to give this a try next spring by building a barge to hold the pump and control the depth of the inlet using a winch I took off an old boat trailer. Then use a long pole to stir the muck up so it can be sucked up out of the lake.
2016 Ford Transit 250 Passenger Van (A55852)
2016 Ford Transit...
2012 VOLVO VNL (A55745)
2012 VOLVO VNL...
John Deere 568 Mega Wide Plus (A60462)
John Deere 568...
2014 HAMM H11IX PADFOOT ROLLER (A60429)
2014 HAMM H11IX...
New/Unused AGT Industrial SDA-140W Mini Wheel Loader (A57454)
New/Unused AGT...
2025 40ft 10-Door Shipping Container (A59228)
2025 40ft 10-Door...
