Ceiling joist support
   / Ceiling joist support #1
tree grower
Cuttingsville, VT
Ford 1210, Bobcat 742B, John Deere 1050
Will soon build a 20 x 32 building for my Christmas tree sales. There will be no interior partition or post supports, so I need advice re: supporting the center of the ceiling joists (collar ties). The easy answer is to buy 20 ft dimension lumber, but it would need to be sawed special. I would like to avoid using trusses if at all possible--I'm a rafter guy. Two possibilities come to mind. 1, butt 2 ten footers together and splice them with a 4-footer. They will need to support me and a helper while we build the roof, but I won't be storing anything overhead. 2. laminate a carrying beam 32 ft long using 2x8s or 2x10s. My greatest fear with this option is that such a beam is heavy all by itself, and may sag in the middle. BTW, it will have 10 ft walls. I eagerly await some thoughts on this issue.
   / Ceiling joist support #2
Don't hate me, but everything you said will sag. You would either need a steel or lvl center beam, or use I-joists.
   / Ceiling joist support #3
A real lumber yard will have 20ft 2x10's not a box store.
you could put in a temporary post and beam for construction and remove it when done
All that said I used trusjoists on a addition at my cabin and fell in love with them square lightweight and flat I would be hard pressed to go back to regular joists and they were cheaper to boot.
or build your trusses your self google truss plans
tom
   / Ceiling joist support #4
My workshop is 25x25, and I bought a 30' steel I-beam, and used
simple select structural DF 2x8 wooden rafters. I went with a bit
bigger beam than the calcs called for so I can support 1000# on a
trolley hoist at mid span. No sagging, cost less than wood, and
weighs a lot less than wood.
   / Ceiling joist support #5
ceiling joists and collar ties are two different structural members and are subject to differnt types of loads and resistances.
collar ties are generally placed 1/3 of the total height* below the ridge and help prevent the walls/beams from being forced outward.
ceiling joists are basically non structural and are for the most part deadwood to support the ceiling although their tensil strength does add to the overall strength of the structure.
* heigth from top of wall/beam to top of ridge.
   / Ceiling joist support #6
+1 :thumbsup:
   / Ceiling joist support #8
If you're looking to avoid trusses and don't plan on putting anything up there then just use 14' 2x6 nailed and glued together to span the 20' way. You'll need a good ridge beam to support the 32' span. My old neighbor did it by making his own truss for a ridge beam.
Basically he put up the walls with the end walls matching the roof pitch. He then used 2x6 nailed and glued together to tie the walls together spanning the 20' direction. He used 2x4s to support the 2x6s temporarily while he built the ridge beam (a copy of a floor truss) resting on top of the 2x6s.
I think he started off running a single 2x4 the entire 32' foot length nailed to the 2x6s and butting the ends of the 2x4s together. He then ran a second run of 2x4s with glue and nails to offset the joints. I think he used 12' long boards so the gaps were 6' apart. He then made what looked like a short wall and glued and nailed that on top of the two rows of 2x4s. He finished it off with two more rows of nailed and glued 2x4s. After that was done he cut diagonal 2x4s and wedged them between the horizontal and vertical 2x4s. The last thing he did was nail 2x6 to the sides of the vertical 2x4s going all the way from the bottom of the 20' 2x6s to the top of the roof. I think he even put a little bit of an arc to it so when he removed the temp posts it would settle level.
It's lasted 15 Vermont winters with no problems but I think it's a lot of work and I'm not sure how much he saved.
Think of these but with about a 4' height.
   / Ceiling joist support #9
Another option you have is to use a scissors rafter system. You can build it like you do with standard rafters and joists except instead of a ceiling joist the scissor rafter runs from the plate on one side up to a point high on the opposite rafter. So it is a little longer than a joist. Connect the scissors where they cross. It is very strong. You would have to call it a simple truss.
   / Ceiling joist support #10
This is the right answer. If I understand the building you are planning, you don't need ceiling joists - they would be a waste of money. I would stick build it also, if you have the time. I've done a number of buildings about that size and found stick building to be cheap and easy. If you want the strongest possible roof (and like doing carpenter work) stick build a full hip roof.
   / Ceiling joist support #11
ceiling joists are basically non structural and are for the most part deadwood to support the ceiling although their tensil strength does add to the overall strength of the structure.* heigth from top of wall/beam to top of ridge.
I would strongly disagree with this statement for a building in VT where you need a 40 or 50 lb/sq ft roof system. A building with standard rafters and no joists to hold the plates together would split right apart. Your right that collar ties help but they won't do the job. The purpose of a collar tie is to hold the tops of the rafters together in high winds. Needed on steeper roofs because you get an airplane wing lift effect on the roof which tries to pull the tops of the rafters away from the ridge pole.
   / Ceiling joist support #12
Do yourself a big favor and frame the walls in 2x6 studs and use a triple LVL to span the entire length then you can use shorter dimensional lumber for ceiling joists, I would also consider LVL for your ridge board as well.
   / Ceiling joist support #13
I understand the live load reqiuirements in heavy snow zones, I was responding to the OP's original questions and terminology.
Unless you are applying some tornadic activity where drastic pressure differences and shear are common the idea that there is any type of "airplane wing lift" on a roof structure is ludicrous. Wind does indeed create lift on any exposed structure but it's not the same as air passing over a wing.
Not sure what you mean by a ridge pole as the OP stated there would be no interior supports. As far as a ridge board, they have very little structural effect, they do add some longitudinal tensile strength, but they are mostly used to make common rafter framing easier, there are many "stuck" roofs that have no ridge boards, the decking/sheathing/purlins serve the same purpose structurally.
edit:
One other purpose of a ridge board is to extend the ridge for the gable etc. eaves, allows a barge type rafter to fastened by something other than just hung from the sheathing/decking.
   / Ceiling joist support #14
Oh boy, these threads are fun. I think I'll throw in my 2 cents, get a beer and sit back.
My recollection of the building code is that collar ties, rafter ties and ceiling joists are three distinctly different things. Collar ties, as noted are in the top 1/3 of the peak, prevent uplift splitting of the roof, and are not intended to prevent wall spreading. rafter ties are usually about 1/2 way up or less and are qualified to prevent spreading of the walls. Ceiling joists can function as rafter ties if required. Depending on the loading conditions, rafter ties can be allowed as much as 4 foot spacing.
If proper ties are used, the ridge pole sizing is immaterial, since it only stabilizes the rafter spacing. Using a large beam on the ridge will allow you to do away with ties completely if you can prevent wall spreading. I know a structural engineer who put a peaked ceiling on a 30 x 30 room by designing a steel belt to wrap the top of the walls.
Given the problem originally stated, I still think rafter ties and no ceiling joists are way to go. Maybe collar ties are now required by some codes, but they didn't used to be. I've built some good sized roofs with just rafter ties on every other rafter and they passed inspection.
   / Ceiling joist support #15
What type of loads or forces create uplift at that point on a roof? Other than an overhang at a gable end and at the eaves, where, how can there be lift?
edit:
should have said "enough" lift to cause damage.
   / Ceiling joist support #16
Wind loading. High winds will take a roof off intact unless it's secured with tie down straps. I've seen a properly braced roof (but not strapped down to walls) carried 100 feet and left in one piece. However, without ties of some sort, the wind will lift it and snap it in two along the ridge.
If you see a house with a vaulted ceiling that has a flat section at the top, it has collar ties. If it goes to a peak, it should have straps holding the rafters to the walls (not just nailed) and a larger ridge beam to allow a stronger attachment of the rafters at the ridge.
   / Ceiling joist support #17
Not a reply to any particular previous post but it has been shown in hurricane zones that full hip roofs with little or no overhang are practically impervious to the same force winds that can decimate gable or similar roof structures.
acknowledge previous mention of hip roof strength by another member.
   / Ceiling joist support #18
My first choice for such a building is pre-engineered trusses. TJI's can be used as rafters per their web site; but they aren't rated for direct weather exposure as I recall. Any exposed to the elements portion of the TJI needs to be enclosed somehow.
Would a clear-span steel building work for your application?
   / Ceiling joist support #19
Another vote for trusses.
Every time I have compared stick-built vs. trusses, the trusses are less expensive than just buying the lumber to stick build. Not to mention the labor savings.
As has been mentioned, a scissors truss system will give you a large clear span and a vaulted ceiling.
   / Ceiling joist support #20
My dad told me a story about two homebuilders back in the 60's that were in disagreement over the stregnth of trusses vs stick built roof systems. They settled it with a bet. They would each build a house with their preferred system (both were big volume builders) and they would test the roof by setting a car on the top of each house to see if it would hold.
The truss system survived while the stick built house required some repairs and some auto bodywork after a few hours.
A volume buyer can get materials and a good crew can definitely build a stick roof cheaper than pre-built trusses, but an engineered truss is proven stronger.
2023 Chevrolet Tahoe SUV (A59231)
2023 Chevrolet...
2021 Ver-Mac PCMS-3812 Solar S/A Towable Trailer Message Board (A55973)
2021 Ver-Mac...
FOUR WAY BLADE SKID STEER ATTACHMENT (A58214)
FOUR WAY BLADE...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
JOHN DEERE 850K LGP (A58214)
JOHN DEERE 850K...
