Century c42 Not starting...a mind puzzler...(my mind anyway!)...help appreciated
   / Century c42 Not starting...a mind puzzler...(my mind anyway!)...help appreciated #22
Re: 2005 Century C42L Turns over but does not start
I am hoping you found the problem and will share how you corrected,I just bought Branson 2910i non-running and the stop solenoid is not getting any fire,just like your problem, the stop solenoid is on top of injection pump,my brother took remote starter button connected one end
to postive side of battery and other end to stop solenoid,had me turn key just like I would do to start tractor and it started,first time in 5 yrs.
the people said I bought tractor from,now we need to find reason no power is going to stop solenoid.Oh I have service manual and chassis manual bought them from Big Red's Equipment.net here in Texas
These ignition switches can be troublesome.....check your fuses..trace the wire back from the solenoid back...prolly goes to a relay under the dash or the ig switch.
The lack of a solid service manual regarding the electrical side of these babies is the Achilles heel.....otherwise these tractors are pretty bomb proof.
2009 Landoll 435A 50ft. 43 Ton T/A Tilt Deck Equipment Trailer (A60460)
2009 Landoll 435A...
DEUTZ MARATHON...
2020 Kinze 3505 High Speed 6/11 Planter (A56436)
2020 Kinze 3505...
7018 (A59228)
7018 (A59228)
2023 FORD F-150 XL CREW CAB TRUCK (A59823)
2023 FORD F-150 XL...
2018 Grove TMS 700E 60 Ton Quad Axle Crane Truck (A60460)
2018 Grove TMS...
