Update on testing the Netgear LB1120. The $15 mimo antenna I purchased off eBay came in so I decided to retest the Netgear modem. I am still not using it on the ideal side of my house but to do so would be more involved and end up with the modem in a hot garage or attic. With the external antenna plugged in it loaded up in 4G. I had to restart the modem to get it to connect after the first attempt failed.
Here is a pic of how I have it set up.
Here are the speed tests after it got stabilized.
Neither are as fast as I've seen with my ZTE Velocity but the Velocity goes through spells of having to be restarted and sometimes the restart has to be repeated often. Not sure how or why but I can clean the sim card and it seems to help with the Velocity. I was hoping for faster speeds and more stability but I will settle for one or the other. Seeing as how the speed is not faster I am hoping for better stability. Time will tell.
Soooo, while the Netgear may produce faster speeds than the Mobley for some it isn't any faster than my Velocity was, at least not for me and my location. The velocity was not actually much if any faster than my Mobley with both in the same position. I originally had the Mobley taped to the window and I think the heat killed it. I had the Velocity in the same spot but it was tied on the room side of the blinds to keep the direct heat of the sun off of it. FYI the blinds will remain closed to keep some heat out. I just opened them to place the mimo antenna and take the photo. The router needs to stay in the window sill for my wifi cameras.
At the risk of repeating myself my sim got moved before the update occurred that locked it. I did not have to use a pin or PUK code to get this working. Hopefully the change will not get my account flagged and locked. The first change resulted in AT&T recognizing my device after some time passed. Maybe it will just do the same with the Netgear.
Those of you that are trying to go straight from a updated Mobley to a Netgear will have to go through getting the unlock codes.
