Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #491
now that your'e tethered - any thoughts on the download/upload speed comparison?
seems some get good increases in speed- and other folks didn't gain much. i did see the 25 meg reference, was it a lot slower before the tether
just went past my 22 gig ( day 8 - NICE to be able to stream, you tube vids ) and so far can't tell the difference...:cool2: getting about 11meg down today,
but thinking about building a DIY $10 Yagi for the mobley
I hear ya, on dropping an over priced internet service.
Virtually no difference in speed whether I connect to the Mobley or connect to the Asus. Im seeing almost 30 mbs down today. Doesnt make a lot of sense seeing an increase in speed behind the router. I call BS on that,
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #492
Right, i thought it had more to do with the antenna , and since most routers have a larger and in many cases multiple antennas the increase in sig strength allowed for faster speeds - especially when more rural with weak signals?? That is why I mentioned building an antenna,
don't really need a stronger wi fi signal for other devices on the property,
but would like to maximize speeds.
seems an antenna might (gain):D me something
especially since the signal is never better than - 106dBm and stormy weather knocks it right down to about -117dBm.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #493
The router will definitely increase the wifi signal strength but it will not increase bandwidth.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #494
What about if you plug into one of the ethernet ports on the router? So your signal path is Mobley-Asus via USB, Asus-computer via ethernet.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #495
No idea, haven't tried that. But my QSee surveillance system will be hard wired to the Asus. The QSee is not wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #496
You're talking about different things. The Mobley has an internal antenna for communication between it and AT&T's cell tower for Internet to/from traffic. The router has an antenna (or multiple) for use in broadcasting wi-fi signal communication between wi-fi enabled devices and the router. While both are important and if either is poor you may suffer poor performance, having the best wi-fi antenna in the world on your router won't do a darn thing to get your Internet-sourced downloads to your device any quicker. These days wi-fi bandwidth is so good that even with only 1 or 2 bars of signal between your phone and router it likely can still handle the entirety of whatever your Mobley or other Internet connection can provide. Now that super good wi-fi signal can be useful if you are communicating between two devices on your own LAN (inside your house), such as uploading pictures from your phone to computer's hard drive.
Don't get me wrong, having a good signal for everything is a good thing and the stronger the better. But it pays to know what each one does and how it may affect your usage.
Rob
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #497
The Mobley actually has 2 antenna that communicate with AT&T and 3rd that likely is wifi. I did connect 2 antenna but didn't see any improvement over the single connection (92dBm vs 108 no antenna). I'm not a real techie, so limited info here. I'm guessing the software doesn't take advantage of the 2nd connection. At any rate, I'm very pleased with the performance with the single antenna.
Guess I could have tried the wifi antenna but did know how to measure. Maybe an iPhone or laptop setting I'm not aware of?
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #498
Regardless of what antennas the Mobley has (which does include the ISP-side one(s) for AT&T signal and the wi-fi one for allowing devices to connect to it), the original question was whether tethering a Mobley to the Asus router would somehow improve the download speeds the Mobley is getting. And it wouldn't.
It is true that the Mobley's own wi-fi capability is fairly limited. That's because it is meant as a mobile hotspot to be used within a vehicle so distance from client devices was probably assumed to be pretty small. Tethering it to a router has the very real advantage of allowing client devices to use the Mobley's Internet connection from much further away. And this TM-AC1900 router seems to be really good at that. I can connect from outside quite a ways away on my property (probably 300 feet or more).
If you want to measure wi-fi signal strength from the Mobley or a router look for an app called "WiFi Analyzer" in Google Play (for Android phones) or Microsoft Store for Windows PCs. No idea what is available for iOS devices.
Rob
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #499
I agree, Rob. To my limited knowledge the router would be its own wifi even if using same network name, the Mobley unaffected.
My house is likely not very wifi friendly. Basically 4 separate boxes with concrete sips framed by galvanized channels, topped with a 2 layered metal sandwiched roof. I basically access the Mobley wifi in same room to check the website, but it is useable there. What makes mine more useable is the Picostation which gives me Omni directional useable wifi from my roof. I might play with the settings to see if I can broadcast a stronger signal, but this is uncharted territory for me. How I get around the in house wifi is a set up of an Ethernet connected router in each box except the garage and tractorshed which extend wirelessly. Didn't think when I built the house I would want wifi in those 2 places, boy was I wrong.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #500
Im sitting about 500 feet from my all brick home running 20 mbs down from the Asus connected USB to the Mobley. Gotta love it. My chickens have wifi now
New Kivel Walk Behind Pallet Forks (A50774)
New Kivel Walk...
2015 Nissan Frontier SV 4x4 Pickup Truck (A50323)
2015 Nissan...
1999 LBT INC FUEL TRANSPORT TRAILER (A52472)
1999 LBT INC FUEL...
2005 GMC Sierra Pickup Truck, VIN # 2GTEK13T851399344 (A51572)
2005 GMC Sierra...
43019 (A51691)
43019 (A51691)
Rears 1000 Gallon Orchard Sprayer (A50120)
Rears 1000 Gallon...
