Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,281
Hmmmmm...My router won't connect to the mobley anymore....problem started 4 days or so ago, and now I see others with the exact same problem. I can connect direct to the mobley and have internet, which is what I've been doing. Since we are all experiencing the same problems....what is going on?
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,282
I suspect an upgrade to the mobley firmware. Haven't checked yet.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,283
My problem is different. Can't see or connect to my Mobley. Router network is fine. Just tethered my phone to the router and have internet through that.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,284
That seems like a possible reason. My Mobley is at VM6200V1.0.1 for firmware, which is a version referenced online since at least 3/2017, so mine doesn't seem to have had an update. I have had no issues with router connection but also have not power cycled or disconnected for a while.
Rob
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,285
No issues for me with my Asus Router. If I was you I would power everything down and bring it back up. Make sure you have a link light on the USB port of the router. If not, disconnect the USB cable and reconnect.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,286
Done all that. I looked at logs, modem wont connect. I can manually try to reconnect it, but it drops out.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,287
What version is your Mobley firmware at?
Rob
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,288
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,289
I can't access my firmware version other than what is on the label. Reads VM6200MD_C.
Have restarted Mobley and router several times with no change. My problem started a couple of days back when the unit became untaped from the window and speed slowed way down. I restarted and taped it back up and it went right back to 15 Mbps. This morning it was dead and I found the tape had given up the ghost again. I cleaned the window and taped it back up and restarted everything but the Mobley is dead. It didn't fall or get damaged because the wires caught it. It was just hanging down from where I get max signal. I get a green LED on it when I power it up but it never gets a signal or can be seen in my network connection options.
Had this happen last year during a hurricane and it came back in a day or so. I can't remember if I tried to log into the wifi manager then. Maybe it will be back soon.
   / Cheap $20 a month Stand Alone Unlimited Rural Internet through AT&T Wireless #1,290
You'll have to log into the Mobley's admin interface in order to look at the firmware version. All the label shows is what it shipped with.
Rob
Caretree Tree Spade (A57148)
Caretree Tree...
2014 Chevrolet Express 3500 Cargo Van (A55852)
2014 Chevrolet...
2012 DIAMOND T TRAILER TRAILER (A58216)
2012 DIAMOND T...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
4 POLY PIPE (A58216)
UNUSED ELK AR500 3/8" STEEL SHOOTING TARGET (A58376)
UNUSED ELK AR500...
