Choker Cable Size Recomendation
   / Choker Cable Size Recomendation #1
Beltzington
Platinum Member
Appling, Georgia
JD 3720
I have grown tired of dragging chain around and it coming undone and would like to try a choker cable. Started to order one from Baileys and see there are several choices. I have narrowed it down to two, the 3/8" @ 14,000 pound rating and the 1/2" @ 26,000. I will be mostly pulling southern pine <4" diameter trees. Go big or go home is my usual solution but not sure how much flexibility (ease-of-use) I would loose with the 1/2" compared to the 3/8"?
Never used cable before so your experience would be appreciated.
Pre-Made Fse Choker 3/8"X12' (5 Lbs) | Chokers | Chains, Cables & Grapplers | www.baileysonline.com
   / Choker Cable Size Recomendation #2
On my 4 inch firs, I used old ski rope. Never broke it. :)
Up to about 12-14 inches, I used 3/8 cable. Never broke it, either.
Bruce
   / Choker Cable Size Recomendation #4
Unless I misread your post you said trees less than 4 inches in diameter.
Choker chains need to be hooked to something with good weight to make them choke down so the chain links dig into the log. They are a pain with small trees. Just not enough weight to make them work. And if you try to choke up on five or six little trees to make weight the middle ones slip out. You will have better luck if you make two wraps of chain around the tree. Then tighten the choker by hand because the chain won't slip round the tree easily to self choke when doubled. But it will hold better.
With light trees your choker line has to be very flexable to grab. I can't see 1/2" or even 3/8" cable that I have used wanting to close down around a 4" tree unless it is very very flexable. I would try the rope suggested by bcp.
   / Choker Cable Size Recomendation #5
The 3/8 cable choker will handle trees larger than your tractor can pull.
   / Choker Cable Size Recomendation #6
I misread the
post
   / Choker Cable Size Recomendation #7
I misread the
post
Perhaps you might want to try something like the the Amsteel Blue rope we used to replace the winch cable on our plow. It's light, but has amazing strength amd very good abrasion resistance. It is definitely not cheap, but sales do happen, if you can afford to watch amd wait for them.
http://www.wesspur.com/rope/amsteel-blue.html
http://www.riggingwarehouse.com/pro...E01@@2e03@@2e02/ROPE01@@2e03@@2e02@@2e01.aspx
http://www.amsteelblue.com/amsteel-blue-3-8-synthetic-winch-extension-17-600-lbs/
http://www.westmarine.com/webapp/wc...=11151&productId=38118&langId=-1#.Uoawi8e3PMI
http://www.amazon.com/s/ref=nb_sb_noss_1?url=search-alias=aps&field-keywords=amsteel+blue
These are just a few of the sites for it that I found in a quick search.
Thomas
   / Choker Cable Size Recomendation #8
Samson Amsteel Blue: Super High Strength Rope
Samson Amsteel-Blue
Amsteel Blue 3/8" Synthetic Winch Extension - 17,600 lbs - AmsteelBlue
SAMSON ROPE AmSteel-Blue Dyneema SK-75 Single Braid at West Marine
Amazon.com: amsteel blue
Thomas
some of the new fiber products are amazing...just look at the braided fishing lines...some 50#+ test braided lines are as small (dia.) as 6#-8# test monofilament...!
   / Choker Cable Size Recomendation #9
I use a poly fabric straps and choke around the tree using a shackle as the choke point. I then use a shackle to connect to the chain. I have a couple 20' chains that I have installed a open type hook about 2' back from the grab hook, the bight of the chain then slides through the smooth hook and really chokes down tight even on small stuff. To each his own but I hate to use cable unless it is fine strand and very flexible. You hate wrestling chain, wait till you mess with stiff cable in the snow with gloves on. Problem with fine strand wire cable is the outer strands break easy and leave all those little wires sticking out to tear up your hands and gloves. I will stay with straps, shackles and chains rigged my way. Voice of 70 years experience with many rigging set ups.
Ron
   / Choker Cable Size Recomendation #10
Both of those cable sizes will be too stiff for 4" trees.
2022 Ford Explorer AWD SUV (A55853)
2022 Ford Explorer...
John Deere BD1108 (A50123)
John Deere BD1108...
2022 BOBCAT T76 PLATINUM R-SERIES SKID STEER (A52706)
2022 BOBCAT T76...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A55853)
2014 Glasstream...
NEW 2025 Load Trail 83IN X 14IN Single Axle Utility Trailer (A55302)
NEW 2025 Load...
2015 Volvo VNL 64T (A55302)
2015 Volvo VNL 64T...
