slowrev
Elite Member
MossRoad said:I'm not frustrated, nor am I going to spend $$ on "good" lights. There has to be a simple explaination as to why that one socket keeps blowing bulbs.
As for how Christmas light strings work, I have a pretty good handle on that...
All the bulbs in a section are wired in series.
All the bulbs have a shunt inside them.
If the filimant blows, the shunt lets voltage through.
If half your lights are out, you probably have TWO sections.
One of the bulbs probably has a bad shunt.
Finding the bad bulb can be a problem.
A product like the Light Keeper Pro can find and repair bad shunts without having to hunt for the bad bulb. It sends high voltage down the line and snaps the shunt back on. Then you just look for the bad bulb and replace it.
However, I know where the bad buld is. I just can't get any bulb to work in that socket.![]()
the little mini series type bulbs have different operating voltages. A 100 light string will have a much lower voltage bulb than one from a 35 light string. If you put the 100 light blub in the 35 light string it will blow.
