Christmas Light Question
   / Christmas Light Question #31
3RRL said:
Well,
After reading this thread and downloading that Light Keeper Pro video, I jumped in the truck and went to Lowe's. Guess what? My Lowe's has never heard of it.:mad: I asked around and they told me to look in the seasonal Christmas section and there was nothing there either. Bummer! I live in Southern California, so is it just a back East thing?
Golfgar4 says he got his at a Ace Hardware in Havasu City. I guess that is east of you. :D
   / Christmas Light Question #32
MossRoad said:
That's in South Bend, Indiana, for those of you that are going to make the drive! :D
The one in Mishawaka has one less as of about 2:00 this afternoon. And the Menards near there has about 300 sq ft less laminate flooring. Guess what I'll be doing this week!?!
I handed the light tester to my 12 year old son who will attack the problem spots... after scouts.
   / Christmas Light Question #33
If many of the bulbs had the filaments open then the shunt kicks in and the remaining bulbs get higher voltage. The higher voltages causes the new bulb to burn out.
Another scenario is that the replacement bulb is a different current (probably lower) than the existing bulbs and as such is subjected to too much current when intalled. Does any of this make sense?
Yeah!!!! It works!
First, the problem with one socket that blows bulbs on that one string....
I have tens of these sets of lights. I have the original boxes that they came in. I have all the spares for these sets in those original boxes.... all of the spares in all of the boxes blow when put in my sets! I moved one light over from a different socket on the string and it works. I measured resistance on the spares and from lights on the sets. They are different. The ones that blow have a lower resistance than the ones that are in the sets. Therefore, I think all of the spares are for 35 light strings and not 100 light (50 per section) strings. Factory bad. Yikes!!! I ended up sacrificing one of these strings for spare bulbs.
Second, I have dozens of old strings that do not work, or only half of the string works. I replaced them over the years with new strings, but did not chuck them, as "Some day I'm gonna fix those things!"
Well, today is that day. The Light Keeper Pro actually works! I pulled a bulb from a dead string, stuck the empty socket into the Light Keeper Pro and pulled the trigger. Nothing happened. The directions said to pull the trigger up to 20 times. So I started clicking away. After 5 clicks about a third of the lights came on! A couple more clicks and more came on. 15 clicks or so clicks and all but about 5 came on. I started pulling those bulbs and testing them in the Light Keeper Pro's tester. They were bad. I replaced them and the entire string is good!!! So I'll let you all know how things go later in the evening. ;)
   / Christmas Light Question #35
tallyho8 said:
I would take a working bulb out of the socket next to the one that is burned out and try it in the bad socket. This is just in case that your replacement bulbs are accidently the wrong voltage. If this fails to work, check the voltage in the bad socket with a voltmeter and the voltage in a good socket and see if they are the same. If the voltage is the same, then we go to the next step.....
I guess we don't have to go to the next step now. MERRY CHRISTMAS :D
It worked good. Thanks!
I repaired about a dozen strings tonight and chucked three as they had back sockets and or had every bulb blown in a string. The things works good for resettingt the shunts, but I cannot figure out how to get the beeper to find where the voltage stops yet. Good gadget for the money. The bulb and fuse tester work fine, too.
   / Christmas Light Question #37
I suggest that everyone here that has light sets that don't work to send them to The Moss Road Orphanage Home for Unwanted Christmas Lights..:D Bird.... you said that you are going to throw your present ones out and buy new next year. Put them to good use and send them to Moss Road...
Dusty
   / Christmas Light Question #38
So you've got the place that the airplanes are mistaking for a landing beacon!!!
Ford F-450 Utility Truck (A55218)
Ford F-450 Utility...
2018 FORD F150 Ext Cab 4X4 Pick-up Truck (A53422)
2018 FORD F150 Ext...
2013 Nissan Rouge SUV (A53424)
2013 Nissan Rouge...
2015 KENWORTH T680 SLEEPER (A54607)
2015 KENWORTH T680...
2008 KOMATSU PC200LC-8 EXCAVATOR (A52706)
2008 KOMATSU...
