Ck weird electrical.
   / Ck weird electrical. #1
pickeringchris
My CK27 has 80 hours and has run flawlessly for the year and a half I've had it. I just noticed 2 weird electrical things.
1) headlight switch. In the off position the lights are on. Key or no key. In position 1 they are off and in position 2 they are on.
2) glow plug light does not go out after 8 second. It will stay on for 60 seconds if I leave it.
Any thoughts would be appreciated.
Thanks
   / Ck weird electrical. #2
glow plug would be your timer relay. light problem is weird.
Ya the headlight thing is a mystery. I put the tractor away and the next morning it wouldn't start. I charged the battery and as it charged the headlights went on. It was clear at that point, the headlights being on was what caused the battery to die. I immediately checked the switch and it was in the off position. I turned it to position 1 and the lights went off. Position 2, they went back on. After charging I went to start and noticed the glow plug light wouldn't turn off. The timing clearly indicates the 2 problems are related.
   / Ck weird electrical. #4
Ghost in the machine. Do you have a Service manual? I have one but its for the DK series.
   / Ck weird electrical. #5
Chris my first thought is water/corrosion in a connector somewhere. Any chance of that? A service manual is a must for this.
Yes I have a service manual. Not that I can understand it. I will probably contact my dealer since its still under warrenty.
The tractor is always stored in a heated garage. I did wash it a couple weeks ago. Any source of water would have had to come from washing it. Is that enough to corrode something?
I have the manual opened on electrical system. I think I got the wrong manual. It's written in Chinese or something. Lol
   / Ck weird electrical. #9
Only thing I can think of is maybe water accidently got sprayed on one of the connectors, and started corrosion or something, but I could be way off base here too. I wonder how close the electrical schematic is to my DK. I take it you are not used to reading electrical schematics.?
Is this what you need James?
2011 DOOSAN G25KW GENERATOR (A55745)
2011 DOOSAN G25KW...
large capacity skid steer bucket (A56857)
large capacity...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
2022 Ford F-450 Liftmoore Crane Service Truck (A59230)
2022 Ford F-450...
UNUSED FUTURE XLA59 - 59" DRUM SPIKE LAWN AERATOR (A52706)
UNUSED FUTURE...
2022 CATERILLAR 303.5 CR EXCAVATOR (A60429)
2022 CATERILLAR...
