CK2610 looses power at half tank fuel
   / CK2610 looses power at half tank fuel
Took about 4 minutes to swap the filter assembly. Now, note, im sitting a full right now, but it primed quickly, and started right up.
12mm; ratcheting wrench for the mounting screws; the left side one, you only have about 8 degrees of swing, so I'd hate to use a normal wrench.
Now, I still need to run it down to 1/4 tank and confirm fixed; and i also need to replace my 5 gal can, its old, and has some sediment in it, and although I always try to avoid pouring the last cup or so of fuel from can, im sure there is sediment that gets in the tank.
2007 PETERBILT 387 TANDEM AXLE SLEEPER TRUCK (A52577)
2007 PETERBILT 387...
2007 National RV Dolphin 35FT Class A Motorhome (A51694)
2007 National RV...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
2022 Wacker Neuson SM100 Mini Skid Steer (A53472)
2022 Wacker Neuson...
