cold weather starting
   / cold weather starting #21
jimainiac said:
Boy, that sure sounds like a fuel line freeze up, I use the diesel conditioner in the white bottle all year 'round, 3 ounce per five gallons. Keeping the tank full is good advice, too.
Yes, it does lead me to believe the line may have froze up. I also use a bottle of conditioner that I purchased at the dealer and I believe that's the ratio I use (I wrote it on the bottle). The funny thing is I replaced the fuel filter in late October when the weather was still warm so I believe that should not be the problem. I always top off the fuel in all of my equipment before calling it a day so it's ready to go the next time I use them. The same holds true for the tractor. This is why I am so puzzled about the problem.
On another note, when I started the tractor a few times this winter I never plugged in the block heater. I simply gave the plugs between 30 sec and 1 minute then turned it over. Every time a blue puff of smoke would blow out the exhaust. When I did plug in the block heater the last time the tractor started right up but no puff of blue smoke.
On a positive note, because of this problem I went out and ran it again today without a problem. I'll test her again next weekend... unless we finally get some real snow here before then.
Keith
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
13042tx (A55973)
13042tx (A55973)
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60429)
KNOW BEFORE YOU...
MACK T/A DUMP TRUCK (A60430)
MACK T/A DUMP...
Honda EM3800SX Portable Gasoline Generator (A59228)
Honda EM3800SX...
Meyer 8' Snow Plow w/ Bracket (A55272)
Meyer 8' Snow Plow...
