Color Coding on GC Loader Valve
   / Color Coding on GC Loader Valve #11
pcwolf, is your leak from the joy stick side of the valve spools,the detent cap end, or the quick connects?
   / Color Coding on GC Loader Valve #12
DMW ... from the loader disconnect closest to the driver - top inside rear. I have a 2005 with individual hookups.
-Phil
   / Color Coding on GC Loader Valve #13
There's not really anything you can lose, just try to keep everything clean. It might me a good idea to take off the loader, gives a lot better access to the valve. If you ever have to replace any spool o rings, definitely remove the loader.
   / Color Coding on GC Loader Valve #14
Thanks. I will look for an opportunity to observe a rebuild if I get the chance. I have never worked with hydraulics before owning this GC2310.
-Phil
   / Color Coding on GC Loader Valve #15
Replacing the 0 rings on the valve is not much different than fixing a leaking kitchen tap (technically also a hydraulic system). Just be sure the system isn't pressurized. Remove the loader, lower the 3 pt attachment or backhoe so they are on the ground and cannot create any system pressure by dropping. Shut the tractor off. Move the joysticks around, depress the nipples on the quick connects on the valve body your working on. Same goes for replacing any leaking hydraulic lines.Your work on the cooling fan/steering washers was a much more involved job.
2008 International 8600 T/A Day Cab Truck Tractor (A48081)
2008 International...
Vacuworx Vacuum Lifter Pad (A50860)
Vacuworx Vacuum...
2010 Ford F-250 Ext. Cab Pickup Truck (A48081)
2010 Ford F-250...
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2017 Ford Explorer AWD SUV (A48082)
2017 Ford Explorer...
2012 Mercedes-Benz C250 Sedan (A48082)
2012 Mercedes-Benz...
