Comparison/ Validation
/ Comparison/ Validation #31
I am going through the same process buddy. I was all set on a front blower until I realized what a PITA they can be. First the cost, then the space needed to store the subframe when you take it off, then needing to crawl under the machine to hook it up. Plus I need the FEL, so constant switching over.
I am surprised at your price on the LS XR 3135. My dealer quoted $28.1k for the machine with loader. Front blower was another $6500.
The NH dealer suggested using a front blade with hydraulic angling. With the blade mounted on the loader it will be easier to push banks back as the blade can be raised. But another option is getting a used 3pt blower which is easily found. On the drive way, angle the blade to move snow to the center instead of to the edge, then use the rear blower on the return pass...repeat on other side of road. Accurately driving backwards is not critical using this method. I think by using mirrors, it will not be necessary to look backwards. With the LS, hose run from one of the rear remotes handles the cylinder on the front blade.
If you can keep the front blower on all winter, it is not as bad. It depends on what other rashes you may want to accomplish.
Hoping you saw the advice for getting AC with the cab. If you are using the machine in the summer, you will want AC or need to be sure you can keep the doors locked open and have access to front/rear windows opening.
NH workmasters are made by LS, off the same assembly line. Not certain on the Boomers. Any tractor dealer/manufacturer that would sell a cab with no AC is suspect!
You can also get quotes from other Kubota dealers within a few hundred miles and see if you can get your local to match. Or you can get a TYM or any other brand. It is of course your choice.
For the poster that mentioned the front mount Hydraulic snow blower....not without a rear power pack. There is nowhere near enough flow in these machines to drive a hydraulic snow blower alone. I also think the rear power packs are a bad idea. It is much better to have a rear blade on during snow season! Front blower and a rear blade is about as good as it gets!
Yeah LS makes some of the NH not sure on the Boomers but you are right on the workmasters. As for the cab, I know TYMs doors come off. I tried a few kubota dealers, local was 32k plus tax, if I drive out of state, they are 30k no tax, so if i want it a drive is a no brainer.
I did sit on the mahindra emax 25-26hp last night, problem with that one and Im not tall is the foot controls made it so my knees had to be in my stomach
/ Comparison/ Validation #35
I think you were too quick to knok Mahindra out of the mix. The tractors may be built by TYM but once you get above 25hp you have emissions systems and Mahindra doesn't have a DPF so no regens. Mahindra also has a bigger dealer network than TYM and even Kioti so getting service and parts should be easier as well.
Mahindra is deceptive in their wording. They still have to meet Tier IV emissions so using common technology with catalytic converter and EGR the engine runs hot ALL the time to continually burn soot as opposed to dpf system that burn hot periodically.
/ Comparison/ Validation #36
Western PA checking in, 2012 Kubota B2320 100 hours FEL and rotomec 5 foot tiller, $12,000 private sale.
I did some reading on on it. The concept is there and people say their catalytic converter is not listed as a wear part like a DPF is. Either way I agree with you I think they are deceptive as well. Plus the claim that it will never have to be replaced by some or even some Mahindra reps is very bold considering this system has only been out 1-2 years we dont know anything about it yet.
I think they are nice machines. But IMO they are a upcharged TYM.
/ Comparison/ Validation #38
They don't run even close to as hot as a DPF. DOC is a different technology which creates a chemical reaction with the catalyst in the DOC unit to convert the diesel particulate, carbon monoxide, and hydrocarbon gasses into CO2 and water the same way it works on a typical automobile.
In a DPF regen either there is an injector sending fuel directly into the DPF or the computer is making the engine injectors fire on the exhaust stroke to send fuel into the DPF but either way, a DPF needs to reach over 1100 deg F to burn off the carbon buildup and it does that by burning raw fuel in addition to creating high exhaust temperature from the engine to do it.
No your right, but they run hotter across the baseline, doesnt mean thats bad. What he's saying is the Mahindra may run at 180 degrees all the time vs brand x runs at 160, but you are right the DPF does burn at over 1000 degress while it is doing it, good or bad I dont know.
/ Comparison/ Validation #40
Mahindra 1533 VS. Kubota L3301 - YouTube
1997 Sherman and Reilly Drum Line Puller Tensioner Trailer (A59228)
1997 Sherman and...
Toro hr:2213.5 (A56859)
Toro hr:2213.5...
206320 (A57192)
206320 (A57192)
Okada OKB 304B Hydraulic Breaker Excavator Attachment (A60352)
Okada OKB 304B...
2012 Ford Transit Connect Cargo Van (A59230)
2012 Ford Transit...
1998 INTERNATIONAL 9100 WATER TRUCK (INOPERABLE) (A55745)
1998 INTERNATIONAL...
