Compressed air lines in garage
   / Compressed air lines in garage #31
</font><font color="blue" class="small">( If copper is used will the soldier ever crack on the joints at the outlets from pluging and unpluging the hose. I know it has to be clamped tight but there still will be some movement. )</font>
That's why you use "drop eared ells at . . . stub downs" as Gordon suggests. Screw the ears to the wall to take the connect/disconnect load off the pipes.
   / Compressed air lines in garage #32
</font><font color="blue" class="small">( Pete three main choices when it comes to copper. Type M copper with red lettering on the side has the thinnest walls. Type L with blue lettering on the side walls is thicker. Type K has green lettering on the side and it's the thickest.
Type m is rated for more than ample pressure, but to be on the safe side I would opt for L tubing and use drop eared ells at my stub downs.
My two cents
Gordon
)</font>
No way to avoid sounding ignorant here, but what exactly is a drop eared ell?
Pete
   / Compressed air lines in garage #33
Has anyone checked into pricing on Polybutene for airline?
   / Compressed air lines in garage #34
</font><font color="blue" class="small">( </font><font color="blueclass=small">( Pete three main choices when it comes to copper. Type M copper with red lettering on the side has the thinnest walls. Type L with blue lettering on the side walls is thicker. Type K has green lettering on the side and it's the thickest.
My two cents
Gordon
)</font>
Pete )</font>
Pete check the picture.
   / Compressed air lines in garage #35
Here is a picture of a drop eared elbow with a little different angle.
The ears are meant to be mounted to some solid structure, such as a piece of wood blocking or steel plate. The threaded end will accept the pipe nipple going to your water separator or your quick disconnect air outlet depending on your setup.
If your going to have just a quick disconnect and not some sort of filter/water separator at your drop make sure to put a tee with a valve at the bottom to drain the water out. If you were looking at the pipe going down the wall it would be as follows. Pipe running down the wall to the tee and out of the side of the tee a pipe a few inches long going to a 90 looking up then a short piece of pipe to the drop eared ellbow screwed to something solid. Out of the bottom of the tee at least a six inch piece of pipe going to a valve for a drip leg. Sort of like a J with a tail. That way you still have a drip leg.---Does that make sense?? ---If not I'll lay out the fittings and take a pic and post it for ya. there are a ton of different ways to do it properly that is just one idea how. /forums/images/graemlins/confused.gif
Hope this helps
Gordon
Boondox, Thanks for asking I didn't know either.
Gordon, Looking forward to seeing the layout pics.
Thanks,
Here is a pic of my compressor shed i'm working on. Made a 3x3 concrete slab for it, still needs a door. The silicone on the wall is suppose to dry clear. I'm going to line it with styrofoam to keep the noise down and install a outlet box with a switch inside the garage to turn it on and off.
Probably have to wait untill spring to paint it. Its all woods behind me so no one can complain. The pipe work is the next
project.
Compressor Shed
2009 Hyundai Sonata Sedan (A50324)
2009 Hyundai...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52576)
2017 FREIGHTLINER...
2007 CHEVROLET BUCKET TRUCK (A52472)
2007 CHEVROLET...
2014 Ford F-150 Pickup Truck (A51692)
2014 Ford F-150...
(11) 2 PLUG VALVES (A52472)
(11) 2 PLUG VALVES...
Dvorak Model 3072A Hydraulic Ironworker S/A Towable Trailer (A51691)
Dvorak Model 3072A...
