Compressor piping or hose Question
   / Compressor piping or hose Question #32
I ran a millwork shop that used copper tubing with soldered fittings throughout. No rust. No leaks. Worked great. Pricey.
I buy long pre-made hoses and cut them to the length needed - often cheaper that buying plain air hose by the foot. Use barbed fittings with SS hose clamps - never had an issue in 35 years.
   / Compressor piping or hose Question #33
Wawajake,
What did you use for your connecting piece ?
   / Compressor piping or hose Question #34
...........The barbed fitting should hold the connection by itself, the clamps are just a safety added thing.........
Years ago i had a bit of welding slag put a pin hole in my air hose with the resultant leak. I cut the line and just used a brass barbed hose connector like this one and I didn't use any clamps. It's held leak free for years now without any problems. The reason I decided to go the no clamp route is because the clamps would have been always hooking on stuff including my hands as I rolled it up and I had some 300 psi working pressure line that I used on a Stock Car that was made to be installed on a barb without any need for a clamps. I decided if that line can hold without clamps, I'd see if an air hose line would too...and it did.
   / Compressor piping or hose Question #35
True, no clamps are needed if the barbed fitting is sized properly.
My hose/barbed fitting/clamp setup was used for a shop setup.
If I go for longer hoses on a mobile setup there would be automotive type air fitting.
I am in the building process for my new shop and I will use the pressure hose for this shop also. Metal pipe can add water in the system if used in cold climates and copper tubing, if not drained can corrode leaving debre in the lines.
The rubber hose installs easy, no special tools and one person can put it up.
Ltr
   / Compressor piping or hose Question #37
Sorry, but that is completely unnecessary. You can do it if you want, but simple soldering/sweating is fine. I work in a fortune 500 industrial complex, and all air lines are Copper that are just normally soldered. They do use the blue (type L) copper, so it is thicker than the ultra thin M (red) but other than that, it is just like any plumbing. If it is good enough for this incredibly liability averse company, then it works for me.
1989 AM General M998 HMMWV 4x4 Humvee Truck (A59230)
1989 AM General...
JOHN DEERE 750 GRAIN DRILL (A58216)
JOHN DEERE 750...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2008 Audi Convertible - REBUILT TITLE (A59814)
2008 Audi...
2018 KOMATSU PC138USLC-11 EXCAVATOR (A60429)
2018 KOMATSU...
2012 DOOSAN G25KW GENERATOR (A58214)
2012 DOOSAN G25KW...
