Compressors and air tools - CFM vs SCFM
   / Compressors and air tools - CFM vs SCFM #1
California
Super Star Member
An hour north of San Francisco
Yanmar YM240 Yanmar YM186D
I've been curious about the difference between air CFM vs SCFM, ever since I bought a Harbor Freight compressor some 15 years ago, rated 5.1 CFM, that couldn't keep up with a HF die grinder rated to need 4.7 CFM.
Oh well that's just HF's marketing.
But recently looking at something from HF:
"Air Consumption 21 SCFM (3.1 CFM @ 90 PSI)"
Huh? What does all that mean?
   / Compressors and air tools - CFM vs SCFM #2
Google is your friend\.
Here's the link to the complete article: What is SCFM in Air Compressors – SCFM vs. CFM Explained
What’s the Difference Between SCFM vs. CFM?​
SCFM and CFM are both essential values that indicate the airflow rate in a compressor. SCFM measures this value based on ‘ideal’ temperature and pressure conditions, while CFM measures the ‘actual’ air flow rate. CFM is the recognized value for measuring the airflow rate in the United States.
CFM (Cubic feet per minute) measures the volume of air or gas that flows through a compressor in one minute. Sometimes, the CFM rating of an air compressor a manufacturer provides may have a margin of error. Therefore, the best way to determine your air compressor’s most accurate CFM value is to test it in your facility.
   / Compressors and air tools - CFM vs SCFM #4
According ChatGPT
SCFM (Standard Cubic Feet per Minute) and CFM (Cubic Feet per Minute) are both units of measurement used to describe the flow rate of a gas, usually air, through a system. The main difference between them lies in the conditions under which the measurement is taken.
  1. SCFM (Standard Cubic Feet per Minute): SCFM is measured at standard conditions of temperature and pressure (usually 68°F or 20°C and 14.7 psi or 1 atm). SCFM takes into account the fact that air density changes with temperature and pressure. Therefore, SCFM provides a standardized measurement that allows for comparisons between different systems regardless of the conditions in which they operate. SCFM is often used when precise calculations and comparisons are needed, such as in HVAC systems or industrial processes.
  2. CFM (Cubic Feet per Minute): CFM, on the other hand, does not account for variations in temperature and pressure. It simply measures the volume of air flowing through a system in a minute without specifying any particular conditions. CFM is a more general measurement and is often used in everyday contexts where standardization is not critical, such as in household fans or portable air compressors.
In summary, while both SCFM and CFM measure airflow rate, SCFM is a standardized measurement that accounts for variations in temperature and pressure, whereas CFM is a more general measurement that does not consider such variations.
   / Compressors and air tools - CFM vs SCFM #5
According ChatGPT
This is a fair question. I get asked this all of the time, I work for an air compressor rental company.
The simple way to explain this that CFM is a measurement of the air entering the compressor at atmospheric pressure. Your HF compressor rated at 5.1.CFM is a measurement of the air entering the compressor. This can be effected by relative humidity, elevation above sea level, temperature (hotter, thinner air takes more to compress to the same volume).
SCFM is a measurement of the volume of air taken at a given pressure. We never get something for nothing. The 5.1 CFM is a constant volume coming into the compressor. However, the compressor's job is to…… compress the air and in doing so, the volume of the air shrinks in relation to the volume of the air entering the compressor. The measurement of SCFM is calculated or stated at a given pressure. This is why your air tool consumes more air than that compressor makes at 90 PSI. As the system goes up in pressure, the volume of air is less.
I hope this helps to answer your question.
   / Compressors and air tools - CFM vs SCFM #6
According to Gemini AI...
Where is CFM of a air compressor measured?
gemini_sparkle_v002_d4735304ff6292a690345.svg
CFM (Cubic Feet per Minute) of an air compressor is typically measured at the outlet port of the compressor, where the compressed air exits the machine. This measurement indicates the volume of air delivered by the compressor per minute at a specific pressure.
It's important to note that CFM ratings are often provided at different pressure levels. For example, a compressor might be rated at 4 CFM @ 90 PSI and 6 CFM @ 40 PSI. This means the compressor can deliver 4 cubic feet of air per minute at a pressure of 90 pounds per square inch, and 6 cubic feet per minute at 40 PSI.
To accurately measure CFM, you would need a flow meter specifically designed for air compressors. However, manufacturers typically provide CFM ratings for their products, which can be used to select the appropriate compressor for your needs.
https://fluidairedynamics.com/pages... in Compressed,coming out of your compressor.
   / Compressors and air tools - CFM vs SCFM #7
I have found with most air tools PsI really matters. My kobalt 60gal shuts off at 155psi. Others 135psi. A few extra psi really wake up air tools.
   / Compressors and air tools - CFM vs SCFM #8
With more and more cordless tools, I find my compressor sitting a lot more.
   / Compressors and air tools - CFM vs SCFM #10
If you go off the CFM at 90 or 175PSI at least you are sure of what the compressor is putting out where the pump and motor are pushing against what air is already under pressure. I would not buy a compressor that did not list CFM @ at least 90 PSI.
   / Compressors and air tools - CFM vs SCFM #11
Atmospheric pressure, or barometric pressure of the air around us, is 1 bar, or 1 kg per square centimeter. Which equals 10 meter of water column.
Compressing 2 cubic meter of air at atmospheric pressure, to 1 bar over atmospheric pressure, you will end up with 1 cubic meter at 1 bar because p x v is constant. I think its Boyle's law.
So, if you need 10 CFM and 50 psi, you will need a compressor with 500 CFM displacement volume. (How many feet of water column that relates to, i dont know because pounds and inches arent connected to the density of water)
SWICT 78" SKID STEER BUCKET (A60430)
SWICT 78" SKID...
2012 VOLVO A40F OFF ROAD DUMP TRUCK (A60429)
2012 VOLVO A40F...
Club Car Electric Utility Cart (A55851)
Club Car Electric...
2015 VERMEER PD10 PILE DRIVER (A60429)
2015 VERMEER PD10...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
