COMPUTER LCD MONITOR
   / COMPUTER LCD MONITOR #11
RoyJackson said:
killing freakin' aliens is my hobby
Remember, Front sight, Focus and gently Squeeze the mouse button...
   / COMPUTER LCD MONITOR #12
frank_f15 said:
jeff, no special requirements, i do a bit of photo editing but no games, my monitor screwd up yesterday, colors way out of wackm flipping , lines etc, not sure if it was monitor or graphics card, a friend just rought over a spar 17" HANNS LCD and it appears it is my olld monitor as his works fine on my system. i think i will look at 19" NOT WIDESCREEN and see what price i can get on NEW EGG. PLEASE keep info comming
When's the last time you degaussed the monitor?
Roger that...
I've been killing Aliens a long time...ever since I went to Mars in the original DOOM.
   / COMPUTER LCD MONITOR #13
I also have the same Acer unit as Roy, had it since Nov 06, it is on 12 hrs a day 7 days a week, no problems, really like it. It replaced a 17" Dell, Dell still works but I want a bigger LCD and the price was right. Gave the Dell to the wife. All 4 computers have LCD, you will kick yourself for not making the change sooner.
   / COMPUTER LCD MONITOR #15
I'll just confirm what most others have said. No less than 19" LCD monitor, Digital and Anolog inputs, I haven't seen problems with Dell or Viewsonic monitors. I run two Dell 21" LCD monitors with no problems. You will like a larger monitor, trying to view items like "parts graphics" or "electrical diagrams" on the 15" or 17" monitors at work verses 21" monitor at home is a HUGE difference. The company is just starting to get some 19" monitors into the system now (dog-gone bean counters).
   / COMPUTER LCD MONITOR #16
That was another advantage of LCD monitors on the ship. You didn't have to degause them on a daily basis like you did on the conventional monitors. Due to the changing magnetic fields as we moved across the sea, the conventional monitors and TV's onboard would develop color clouds and distorted images daily while underway.
That is why you used to need a TV installer/repairman to set up your TV when it was installed. He used an electro magnet to degaus the screen. Once they started building automatic degausing into the TV's, this need went away.
just an update , I did purchase a new montior i ought a 19" lcd made by LG ( not wide screen) some of the units i like for some reaso were not available in stores , online order only. did not want to do that, and knew i would pay a few $$ more but i wanted to see it first. so i boutght it sat. at 3 pm for $229 and today the same store has it on sale for $199 called and they will refund the $30. as some suggested i bought a monitor that did not really high optimal res. this one has optiomal of 1280x1024 works good for me. still have to figure out the blasted menu tho it seems pretty good out of the box. THANKS FOR THE HELP
   / COMPUTER LCD MONITOR #18
It all makes sense now, Roy, when did you return from Mars..... :eek::D:D:D:D:D
Frank, I see you have your monitor. Another thing to consider is TWO monitors if you graphics card will support it. I can use my laptop with its monitor and a secondary monitor at the same time. Its SOOOOO nice to be able to look at a document on one screen while working on the other monitor.
Later,
Dan
   / COMPUTER LCD MONITOR #19
As far as $$$ goes you might consider a refurb. My last 2 have been refurbs and b/c of the savings I was able to get a bigger screen than if Id bought new. Both are still cooking at this point and have survived 3 moves (two by 'professional' movers).
   / COMPUTER LCD MONITOR #20
That's what I did. Current monitor is a 17" Dell LCD refurbished (cost a little less than a new 15"). The first they sent had a problem (one or 2 pixel wide yellow stripe from top to bottom near the right side edge that came & went). I called Dell & they sent another right out. Two days later it arrived. I packed the old one in the new box (as per their instructions) & sent it back on their call ticket. This one does have a little "mark" on it, but it's down below the clock at the bottom corner, so I can easily ignore it. Otherwise it's been just peachy for the last 2.5 years. :D And you can bet when it's time to get another one, I'll do it again!
2016 Dodge Caravan Van (A53424)
2016 Dodge Caravan...
2011 Chevrolet Traverse 1LT SUV (A55758)
2011 Chevrolet...
2013 Freightliner 122SD Day Cab Truck, VIN # 1FUJGNDR3DDBZ7701 (A54865)
2013 Freightliner...
2008 Ford F-250 4x4 Ext. Cab Pickup Truck (A55788)
2008 Ford F-250...
2018 John Deere 470G LC Hydraulic Excavator (A53421)
2018 John Deere...
2017 Jeep Patriot 4x4 SUV (A53424)
2017 Jeep Patriot...
