Concrete Balast Box Cure?
   / Concrete Balast Box Cure? #11
now that is a piece of concrete.
Shane
   / Concrete Balast Box Cure? #15
Nice ballast. When you make the next one put a hitch point right out the back of the box. You never know when you will need to tow or be towed.
   / Concrete Balast Box Cure? #16
When he builds the next one? :confused: Racer71 just build the brick out house of ballast boxes. That thing is going to be handed down to his next generation. When the big one goes off there will be only cockroaches and Racer71's ballast box left. Seriously, nice work Racer71. Every time I think I'm just going to wonder into the Kubota dealer and buy a overpriced ballast box, someone on here posts a home built version that make me feel like a looser for not taking the time to do the same.
   / Concrete Balast Box Cure? #17
I'm curious - how many bags of cement did you use?
the design looks pretty basic. 1/2" plywood, 1/4" threaded rod, and some corner brackets.
It looks nice, but Id like one a tad bit lighter. Even though the Ford is rated at 3200#'s. I'd prefer to keep the box under 1000#'s
I think I'll do shorter then include some hooks for lifting it up and I'd also add 4our anchor points so if I needed to add more I could just stack them on top.
Wedge
   / Concrete Balast Box Cure? #18
I use chimney blocks. Stack them on end, drive in a rod and fill. They weigh about 100# each filled. "insane"
Hi guys,
That block took 16 bags of quick cement.
$60 cement
$25 drawbar
$20 top link bars
$30 other
I have used it a little and it makes a world of difference. The tractor "feels" solid now.
   / Concrete Balast Box Cure? #20
Good job, I'm just wondering, is it more appropriate to use cement like you did than having a box that you can fill with sand or stones so you can vary the weight depending on conditions?
2024 CHEVROLET SILVERADO 2500 HD BED (A58018)
2024 CHEVROLET...
KMC 70Z7 WHEEL LOADER (A52709)
KMC 70Z7 WHEEL...
2007 Ford F-150 (A55973)
2007 Ford F-150...
2025 BrushFox XHD-78HF 78in Rotary Brush Cutter Skid Steer Attachment (A56857)
2025 BrushFox...
2017 John Deere 1025R Tractor - 626 Engine Hours (A56435)
2017 John Deere...
1992 Ford L900 Cab Chassis with Low Milage Cummins (A56435)
1992 Ford L900 Cab...
