Concrete Balast Box Cure?
   / Concrete Balast Box Cure? #11
now that is a piece of concrete.
Shane
   / Concrete Balast Box Cure? #15
Nice ballast. When you make the next one put a hitch point right out the back of the box. You never know when you will need to tow or be towed.
   / Concrete Balast Box Cure? #16
When he builds the next one? :confused: Racer71 just build the brick out house of ballast boxes. That thing is going to be handed down to his next generation. When the big one goes off there will be only cockroaches and Racer71's ballast box left. Seriously, nice work Racer71. Every time I think I'm just going to wonder into the Kubota dealer and buy a overpriced ballast box, someone on here posts a home built version that make me feel like a looser for not taking the time to do the same.
   / Concrete Balast Box Cure? #17
I'm curious - how many bags of cement did you use?
the design looks pretty basic. 1/2" plywood, 1/4" threaded rod, and some corner brackets.
It looks nice, but Id like one a tad bit lighter. Even though the Ford is rated at 3200#'s. I'd prefer to keep the box under 1000#'s
I think I'll do shorter then include some hooks for lifting it up and I'd also add 4our anchor points so if I needed to add more I could just stack them on top.
Wedge
   / Concrete Balast Box Cure? #18
I use chimney blocks. Stack them on end, drive in a rod and fill. They weigh about 100# each filled. "insane"
Hi guys,
That block took 16 bags of quick cement.
$60 cement
$25 drawbar
$20 top link bars
$30 other
I have used it a little and it makes a world of difference. The tractor "feels" solid now.
   / Concrete Balast Box Cure? #20
Good job, I'm just wondering, is it more appropriate to use cement like you did than having a box that you can fill with sand or stones so you can vary the weight depending on conditions?
2015 Ford F-150 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
Year: 2019 Make: Nissan Model: NV200 Vehicle Type: Van Mileage: 88,557 Plate: Body Type: 4 Door Van (A55853)
Year: 2019 Make...
PALADIN INDUSTRIAL SCREENER (A58214)
PALADIN INDUSTRIAL...
500 BBL WHEELED FRAC TANK (A55745)
500 BBL WHEELED...
2003 Big Tex 10PI...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
