Concrete columns
   / Concrete columns #1
scottbrrtt72
New Hampshire
Hi All,
I wanted to post this project I have been working on. We have a camp in VT that we go to with lots of friends. When it was built we used sections of telephone poles to keep it off the ground. The last camp we had was near a brook. One year during the winter thaw and heavy rains it washed the camp right down stream. So, due to financial reasons and what we thought was a good foundation at the time, we starting building the foundation. We rented a motorized hole auger from the local rental store. Come to find out the ground was rocky and soft in certain areas. Some places were extremely difficult to dig, while others were easy. So we did the best we could with the holes getting them as deep as we could. Little did we know they were not close to the frost line and there was no footing to help with weight displacement. Since we didn’t want to loose this camp to water we kept the poles 2 feet above ground level. The following spring, once the camp was complete, we noticed the telephone poles starting to shift. We did the best we could to brace them but it was just not good enough. The main 2x12’s the floor joist were sitting across started to twist and the poles looked like they were going to eventually tip over. It got to a point when we were lying in bed and someone came inside, the camp would shake when the door was shut. Very scary! So, we all threw around some ideas about jacking up the camp and putting in sonnet tubes. I didn’t think this would do the trick because of weight displacement. We need a footing and sonnet tubes. Concrete was our answer. I did some research and found out they make footings for sonnet tubes. I believe they are called bigfoots and they will fit about any sonnet tube. The other problem we had was how would we pour the tubes. We needed a lot of concrete and would it be cure the next day to rest the camp back down on? So I came up with the idea of pre-fabricating them, haul them up there, and put them in. Since I own a compact JD with a backhoe this was feasible. I started off with the sonnet tubes and the bigfoots. The bigfoots were expensive $17.00 a piece along with a $7.00 sonnet tube and the price of rebar. We needed at least 12 and money was tight. After making three of those and installing them we all agreed this was the way to go but how can we get away with this cheaper. One day I called the local Aggregate Company and asked them what they did with the leftover concrete. I was informed a lot of time they just dump it out. So I built a square form with a footing and asked if they could pour the waist when they have it. They didn’t mind at all. It was an inexpensive solution to a big problem. I made some new friends at the aggregate plant and now I have an open invite to concrete. I treat the guys good by buying them beer, food and coffee. I just finished building 12 more columns and they came out better than the sonnet tubes. Here are some photo’s to check out.
   / Concrete columns
here is the form I made.
   / Concrete columns
here is what they look like after being poured.
   / Concrete columns
this is them in there new home.
   / Concrete columns
yet another one.
   / Concrete columns
last one for now.
   / Concrete columns #8
Those look pretty solid. Any re-bar involved in this work?
   / Concrete columns #9
I was also wondering what size and spacing were your verticals and your ties?
Thanks
Yooper Dave
   / Concrete columns #10
Hi Scott...
That is certainly a different approach... how much did each unit weigh?
I would imagine, it would have to be much easier to do the concrete pour on-site and in place... also I'd consider them to be more of an "underground/in ground" column versus an extended footing... so not only rebar would be desirable, but a steel beam as well... and of course a solid surface to bed all of this...
...otherwise... you may be doing all this again... later /forums/images/graemlins/crazy.gif
2008 John Deere 2305 Tractor (A50514)
2008 John Deere...
2024 AGT INDUSTRIAL QHT-500FL CONCRETE BUGGY (A51242)
2024 AGT...
1266 (A50490)
1266 (A50490)
New Holland 499 Hydra - Swing Mower Conditioner (A50514)
New Holland 499...
2013 KENWORTH T370 DUMP TRUCK (A51406)
2013 KENWORTH T370...
(2) METAL SPOOLS W/ SOME DURALINE 4" PVC PIPE (A51244)
(2) METAL SPOOLS...
