haul your portland cement in, sand in, rock in, then haul a"trailer concrete mixer" and then haul in a skid steer.
--use the skid steer to move everything to into mixer, then use skid steer again to possibly move the wet mix to were it needs to go.
i am with other folks. see about drill down, tossing in some concrete, and then build some posts on top of that. then run a wood flooring.
--if you need to run sewer lines, water lines, LP or natural gas lines, eletrical. you will have in essence a crawl space under the building to access stuff.
--placing the overall building say 2 to 4 feet off the ground. and then put some metal siding or like around the edges, to help keep the critters out from under it possibly. but more than likely to help keep the wind from blowing under it.
most likely you will need a backhoe up in the area. to deal with any sort of trenches, with rocks and tree roots.  a chain trencher more than likely get stuck and not make it.
*rubs chin* backhoe + footer + concrete blocks down below ground to a couple feet or higher above ground = sounds better.  keep more of the critters out. and give you a crawl space underneath.
--if lucky backhoe able to dig in trenches for water, sewer, electrical, gas. and perhaps a concrete floor. without a crawl space at all.
pending on ground, you might get away pouring say 4" to 6" concrete pad. directly on the ground. without footers or like.  many sheds are done this way. "pole barns" and folks having a concrete area for there work shop area, or entire shed.
--if you are going concrete route for pad. you really should be contacting your local concrete companies. and let them bid it out.
--if going DIY route, higher concrete finisher = a must have, they person will have the tools and know how and more so the experience to get the pad level and no major dips / low spots / high spots and get it all nice and smooth.
