Concrete project: will this work?
/ Concrete project: will this work?
Sealer is applied to fresh concrete to slow the cure. The slower the cure, the stronger the concrete. After that, it protects it as stated above. You can get a small 1 gallon bucket of sealer and spray, brush, or roll it on.
I didn't know that. I *assumed* it was just the opposite; that the sealer would ****** moisture from getting to the concrete, impeding it's future strength.
Next time I go to HD, I'll get some and apply it.
No progress today: I have roof work being done, it's in the very low 40's and windy. I'm going to let the concrete adhesive cure on more day, then set the tabletop tomorrow.
Thanks,
/ Concrete project: will this work? #62
Have you considered paint. A good quality oil or water based porch enamel (paint formulated for foot traffic) would last as long or longer than a sealer. The plus side is you could paint it in any color you wanted. Very nice bench.
Unless the sealer is UV resistant it won't be there long. For long term appearance paint it or leave it concrete and don't be concerned with standing water. I believe I read that it is sloped to drain. Good idea.
/ Concrete project: will this work? #63
Thanks,
The water is already in the Concrete, and is working hydrating the Cement. By sealing the Concrete you allow the water to stay in the concrete to hydrate the Cement. When the water evaporates it leads to weaker concrete, as the cement has less water to work it's magic with. We aren't talking about the difference between 1000 psi and 5000 psi; more like 2750 vs 3000. It's not a huge deal, more theory then a huge game changer.
/ Concrete project: will this work? #64
The sealer will help with water loss during curing for the support structure. Paint is bad because it traps moisture. You want a breathable sealer which limits moisture and makes cleanup easier. Look for silene sealer at HD
/ Concrete project: will this work? #65
Not sure where you get this. There are millions of painted concrete structures all over the world.
I used something to make that corner, I guess it's a quarter round.
What should I use in place of the quarter round? Please use small words, I don't do wood beyond 2x4's, 4x4's etc.
You need a cove molding instead of the quarter round. Its the opposite shape of quarter round. Think backwards when making a pattern. This will make a nice roundover on your edges. Any box lumber yard will have it right next to the quarter round you bought. You will have to plane down both edges of the cove to make a full cove. A hand plane would work fine. Good luck with your project.
Is this what cove molding/moulding looks like?
images
I found lots of different cove molding shapes, but this appeared to be the one you're talking about.
And yes, I was trying to break the 90 degree crack-inducing sharp corners for the table top. After the fact, I did "break" them some more via use of the concrete crick rub I have.
While it's too late for this project, in the future, I'll want to break the edge - what should I have used or what's better?
Thanks,
/ Concrete project: will this work? #67
You could also consider vinyl wall base to line your form.
Or cardboard corner protectors.
Or half of a plastic rectangular downspout.
Bruce
/ Concrete project: will this work? #68
For corners in a form like yours, I use a thick bead of caulk. Cut the caulk tube snout about half way down so you get a full bead. I use a plastic spoon to trowel it, leaving a nice smooth rounded corner.
/ Concrete project: will this work? #69
images
Thanks,
Ahh, that's the one. Your corners need a "full" cove so the small shoulders will have to be planed down or these 2 small offsets will transfer to your casting. Easy to do with a hand plane or if you have a jointer.
Ok, if and when the form ever gets used again or if I need it for another form, I'll do that.
Thanks,
And it's done!
Actually, I still need to pull the pad forms (I'll wait until the ground isn't so soggy and muddy) and dress the pad edges a bit plus clean the pad off.
I'll let that sit today and tomorrow (it's in the low to mid '40's today), cut the piece of carpet tomorrow (using the tabletop form as a guide), then it's time to do some shooting!
Thanks for all the help, I appreciate it!!!
[insert beer icon here]
/ Concrete project: will this work? #72
It looks great to me. So how will you get the deer to walk onto your range? :D
Shouldn't be a problem: there's a pretty nice deer scrape right up on my pole barn field which is in the background above the range backstop. There's also one on the trail/track above and to right of the backstop area. Deer are pretty much like rats around here.
Thanks for all the good words, I appreciate it!
Thanks,
And funny you should mention that:
This evening just at dusk, I was in my pole barn sniper's hide (an elevated platform in one corner of the barn) and I saw four deer walk down the track/trail going towards my shop/shooting bench. Since it was right at dusk, plus I couldn't see if they were does or not (probably were but that's all I want to shoot) plus the fact that Butter was sitting in my lap and I didn't want to disturb her.
If you take a look at the last pic above, my pole barn is about 175 yards or so just behind the corner of my shop just up and beyond the poplar grove you see in that pic.
And of course, just as I got down, I jumped another one right at my gate! Scared the crap out of Butter, she had no idea what that critter was!!!!
John Deere 5045E for sale
John Deere 5045E...
2019 HAMM HD+140IVV DOUBLE DRUM ROLLER (A65053)
2019 HAMM...
2021 HYUNDAI HX220L EXCAVATOR (A60429)
2021 HYUNDAI...
Caterpillar D5B Dozer Parts and Service Manuals (A63117)
Caterpillar D5B...
2022 EZ-GO ELITE...
2016 VOLVO EC250EL EXCAVATOR (A62129)
2016 VOLVO EC250EL...
