Coolant Ph
/ Coolant Ph #11
Soundguy said:
Some diesel engines are prone to cavitation and or electrolysis issues. There are addatives which will prevent this, and most of them are calculated by adding a specific volume of addative to a specific amount of coolant, and a test strip is used to verify the concentration.. usually by ph. CNH makes an addative called fw-15 that does this.. etc. It's not that the coolant becomes acidic and etches the cylinder wall.. or sleave wall.. it is actually that cavitation causes the wall to erode.. the reason this happens is due to the vapor pressure of the coolant, and the vibrations from the cyl.. etc. ( very basic explanation )
Soundguy
I have assumed that if I use an antifreeze made for diesel tractors that I do not have to be concerned about adding any additives. Does this make sense?
Bob
/ Coolant Ph #12
While it makes sense, it is not neccessarily always true.
You need to read your particular brand / package of antifreeze and insure that you are using it correctly.
Even some brands, have different flavors of antifreeze that will be used in different manners, or need different additional add packs depending upon application.
Usually what you would be looking for are the words "fully Formulated" or With SCA (supplemental coolant additives)
Different manufacturerers get there different ways, and some manufacturers offer several ways within their own lines.
You may find this interesting reading.
Fleet Charge Frequently Asked Questions
/ Coolant Ph #13
My NH 1925 will be 10 years old in a few months and it has had the coolant changed at 2.5-3 year intervals, first time I used a good green; regular ethylene glycol coolant with a little SCA added (NAPACOOL). tested with the strips and it was on the strong side of normal. Next 2 times I used a pre-charged fleet type coolant and it was about normal on the test strips, added 2 oz SCA a year later to bring it from just the low side of normal range to the high side of normal. Changed it again last week and used the GO5 formula and as of yet I have not checked the readings (test strips expired) and do not know if the strips will even read 100% correctly on all 3 pads with GO5. Too much additive is not good as it is abrasive to water pump seals. Most folks will say SCA's are not needed in non sleeved blocks and of course too much is bad, but all my vehicles cooling systems work well and there is no buildup on the tube openings of inner tanks. If antone wants to read more go to Wix/NAPA Filters or the major filter brand of your choice and read up. NAPA also offers a refractometer #4584 (F readout) #4585 (C readout) to help determine dillution level.
/ Coolant Ph #14
As an added point, you have to know what antifreeze you have, to select the proper tests / test strips to run.
There are various chemistries used and you have to insure that the strip that you are using, is applicable to that chemistry.
As a general statement, I strongly suggest going with one manufacturer, and sticking to one type of chemistry, ie add packs, SCA's etc. that are intended to work together by that manufacturer, and use their test strips (or other tests as they deem appropriate)
Mixing chemistries can lead to problems, I am not sure how these newer "mix with all" antifreezes are doing it. Personally, I think they are playing the odds.
/ Coolant Ph #15
Yes; I know what you mean about the "mix with all" coolants. See a lot of auto shops spec it so one coolant does all. I just can't see how one formula can mix without some loss of performance/protection. I myself will prob use the G05 formulation from now on in all my vehicles unless it specifically requires a more robust additive package. In my opinion DexCool is prob the worst of the ELC's and G05 seems to be the best unless one needs the "adjustabillity" of adding SCA's. I don't think DexCool would have goitten the bad rap it got if it wasn't pushed as a 100,000 mi coolant. Anything other than a regular old ethylene glycol coolant mixture is prob overkill for our compact tractors, just changing it out every few years is the imortant part.
2014 BRODERSON 1C-402C CARRY DECK CRANE (A59823)
2014 BRODERSON...
KBH Mule Boy (A60462)
2009 Bobcat 430 (A60462)
2009 Bobcat 430...
Mahindra 5145 (A60462)
Harlo HP6500 (A60462)
2019 Ford F-350 (A55973)
2019 Ford F-350...
