Cooling cabin with cistern water
   / Cooling cabin with cistern water #11
i saw something like this tried in 1980: water from a well, was pumped thru a radiator mounted in the return air duct: water temp monitored in and out, and adjusted so it increased the temp of the water about 15-20 degrees: as others said, a drip pan was needed: this was turned on when the folks got home from work, about 5:30 or so: it would drop the temp in the house to a comfortable level, until about 11 that night: they where putting the water back in the same well, and about that time, the well water had heated up enough it wouldn't work anymore: the last i heard, they where thinking about a second well..i always wondered why they didn't just water their yard or garden instead of putting the water back down the well?? maybe lack of volume?? i haven't talked to them since about 84 or 85, i guess i need to call and see how it turned out?
heehaw
   / Cooling cabin with cistern water #12
slowrev said:
Would this work ?
I have about a 5,000 gal underground cistern. Would circulating it thru a radiator with a fan behind it work for cooling ? and how many BTU's of cooling would be stored in there before the water all got hot. Remember it is under ground so some re-cooling of the water would happen.
Has anyone done this ?
SlowRev,
Remember that auto radiators are soldered with lead solder. If you use the cistern for drinking water it wouldn't be a good idea to put the lead contaminated water back in there.
Mike
mwechtal said:
SlowRev,
Mike
Nope, the cistern is not used for drinking water. I have a smaller newer one I use for drinking water.
1999 WEST WIND 30FT PINDLE FLATBED DOVETAIL TRAILER (A58214)
1999 WEST WIND...
2021 MULTIQUIP 25 WHISPERWATT DIESEL GENERATOR (A59823)
2021 MULTIQUIP 25...
golf cart (A56859)
golf cart (A56859)
2017 New Holland T4.110 Cab 4WD w/ 655TL Loader – 1,619 hrs – Excellent Condition
2017 New Holland...
2017 FORD E-350 SUPER DUTY 16' BOX TRUCK (A60430)
2017 FORD E-350...
2009 Honda Odyssey Van (A55758)
2009 Honda Odyssey...
