Corn On The Cob,,, - A New Way,,,
   / Corn On The Cob,,, - A New Way,,, #1
CADplans
Elite Member
near Roanoke VA
584 IH 4WD
'tis the season for corn on the cob,,,
I ain't saying the wife is impatient,, but, she has the picnic table set,, waiting for the corn to grow,,
Just kidding,, we read about the method of heating corn in the oven,, rather than hot water.
The oven method is perfect!!
Pull the ears off the stalk, leave the husks on.
Preheat the oven to 355 degrees,, throw in a dozen ears for 17 minutes.
THEN,, I cut off the top and bottom with a serrated bread knife.
The heat makes the silks fall right off as you remove the husks.
no muscles needed,, since the bottom is cut, the husks literally fall off.
There is no need to remove the husks until you eat it,, the corn is perfectly fresh.
(NOTE: if you are civilized,, and eat indoors,,
yea, you can remove the husks while the corn is in the kitchen)
So, the advantages to us are:
No boiling water, the house stays cooler,,,
FAR less labor,,
this is the freshest corn prep method we have EVER tried,,,
Give Oven Corn a try!!
   / Corn On The Cob,,, - A New Way,,, #3
That cobb on the left looks like a beaver got a hold of it
   / Corn On The Cob,,, - A New Way,,, #5
Does it cook the worms, too....???? :) [ THANKS, going to do it that way... SOON...!!!!!!!!!!!!!!!!!!!!! ]
   / Corn On The Cob,,, - A New Way,,, #6
I like to put it in the microwave, 4 minutes per ear, then cut the stalk end off enough for the corn to fall out, hold the tip end and the corn will fall out, clean no silks.
   / Corn On The Cob,,, - A New Way,,, #7
Run some water in the open end of the complete corn cob with husk. Then heat, micro wave, barbecue, oven ??
   / Corn On The Cob,,, - A New Way,,, #8
I will try it... but how in the world did you come up with 355degF and 17min?
The article said to do it for 350 for 15 minutes,,
that was not hot enough for us,
we went up to 355,, that got close,,
the third batch, we upped the time to 17 minutes,,, perfect.
The oven temp is accurate,, we check it frequently.
If you did more than a dozen ears,, I would bet the time would have to go up some to heat all the corn.
The first time we did it, we only did 6 ears,, the other two times,, we did 12 ears.
One time,, we saw a worm,, it did not make it through the oven cycle.
Insects are one of the reasons I like to cut the top off.
usually,, the insect is only in the top 1/2" of the corn.
   / Corn On The Cob,,, - A New Way,,, #10
We do 'em on the grill. Soak in cool water first, turn frequently. Cut the butt, give a squeeze and enjoy.
I like it best when some of the kernels brown a bit.
2018 John Deere TX (A53317)
2018 John Deere TX...
MURRAY PUSH MOWER (A58214)
MURRAY PUSH MOWER...
excavator trenching bucket- one bucket per lot (A56438)
excavator...
2023 CAN-AM DEFENDER RTV (A59823)
2023 CAN-AM...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
2008 JCB 190 ROBOT SKID STEER (A60429)
2008 JCB 190 ROBOT...
