Could someone explain
/ Could someone explain #1
DwayneB
Ky
JD 2240, NHTD80D
To me how the pto clutch on the td80d works. From what I can see this clutch actually has 2 roller bearings unlike the older style 2 stage clutches. The lever on the left side of the seat pushes down to engage the pto. Am I correct in assuming that with the pto off the bearing is in contact with the fingers to keep the disc disengaged? Or am I missing something.
I actually had already seen that. I'm not having any trouble with mine. I just got to digging into drawings and if my suspicion is correct there is constant pressure on the release bearing when the pto is off. Seems like a poor design to me. I can't find anything in my owners manual to indicate a gear that can be disengaged so the pto lever could ride in the on position without the pto actually turning.
/ Could someone explain #4
I would not be concerned.
90cummins
RickB explained to me that it's exactly how it looks. He said they hold up well even with the constant pressure when not using the PTO. I was surprised to hear that. Time will tell I guess. I've read of a bunch of people replacing clutches too early. I figure at a minimum the clutches should last to 4K hrs.
Kivel 42in Forks and Frame Mini Skid Steer Attachment (A64553)
Kivel 42in Forks...
2022 EZ-GO ELITE...
Frac Manifold S/A Trailer (A64194)
Frac Manifold S/A...
2014 FREIGHTLINER CASCADIA CA113DC T/A 6X4 DAY CAB TRUCK TRACTOR (A67148)
2014 FREIGHTLINER...
2012 Ford E-350 Cargo Van (A64556)
2012 Ford E-350...
2016 Ford Fusion Hybrid Sedan (A64557)
2016 Ford Fusion...
