Could someone explain
/ Could someone explain #1
DwayneB
Ky
JD 2240, NHTD80D
To me how the pto clutch on the td80d works. From what I can see this clutch actually has 2 roller bearings unlike the older style 2 stage clutches. The lever on the left side of the seat pushes down to engage the pto. Am I correct in assuming that with the pto off the bearing is in contact with the fingers to keep the disc disengaged? Or am I missing something.
I actually had already seen that. I'm not having any trouble with mine. I just got to digging into drawings and if my suspicion is correct there is constant pressure on the release bearing when the pto is off. Seems like a poor design to me. I can't find anything in my owners manual to indicate a gear that can be disengaged so the pto lever could ride in the on position without the pto actually turning.
/ Could someone explain #4
I would not be concerned.
90cummins
RickB explained to me that it's exactly how it looks. He said they hold up well even with the constant pressure when not using the PTO. I was surprised to hear that. Time will tell I guess. I've read of a bunch of people replacing clutches too early. I figure at a minimum the clutches should last to 4K hrs.
2003 NOBLE 12000 GALLON WATER TOWER TRAILER (A65054)
2003 NOBLE 12000...
2025 BrushFox XHD72 72in Rotary Brush Cutter Skid Steer Attachment (A64553)
2025 BrushFox...
2015 John Deere CX15 (A64126)
2015 John Deere...
SWINGTEC D-88307 COLD FOGGING APPLICATOR (A64276)
SWINGTEC D-88307...
2020 Ram 1500 Pickup Truck (A64194)
2020 Ram 1500...
2018 Infiniti QX60 SUV (A64557)
2018 Infiniti QX60...
