Creating a Lake
/ Creating a Lake #221
</font><font color="blue" class="small">( This guy has got a big problem. )</font>
I got a pic for you. My brohter-in-law and I were working with his bulldozer on a road that had to cross a little spring that feeds his pond. He "accidently" got beside the spring instead of 90 degrees to it. Needless to say he has been stuck before and knew what it felt like. So he stopped right away so as to not sink to deep. Well I can't say that for the method we tried to get it out. He wasn't stuck as bad as the pic you posted but it has to be some sort of record to get two pieces of machinery stuck in 15 minutes of each other.
I think I fixed the pic. I made it an attachment.
/ Creating a Lake #222
Hey Bryan, I can't get the Dab Day pic to come up. Later, Nat
/ Creating a Lake
Thanks for the warnings and advice on the spring. Belive me, I'm terrified of bottomless mud and what it will take to get my dozer out of it!! /forums/images/graemlins/crazy.gif
The main spring is on the other side of my peninsula. I've been avoiding that area until everythign else is done. Once I start to mess with it, who knows what will happen or what type of mess I create.
This is a new spring that appeared after removing tons and tons of dirt that was over it. This was a total suprise to me when water started coming out of the ground during the second dryest year on record!!!!
I eased around the edge of it with the backhoe and took out some dirt to see what would happen. After a few hours of moving mud, all I had a was a dry hole in the middle of muddy dirt. No water.
To finish off my experiment, I dug down as far as I could. My hoe is 14 feet long and can dig a flat bottom 12 feet down. I went as deep as I could. At the bottom I started puling up loads of loose gravel. Small stuff smaller than marbles.
The gravel was wet, and when I was done, the bottom had just a small puddle of water on the bottom.
This morning, the deep hole was full, but the rest of what I dug was still dry.
I'm having doubts about my spring and wonder if I just hit table water. Is there a diference?????
Eddie
/ Creating a Lake #224
Eddie,
I'm guessing you've hit what we used to call a "wet weather spring." It would only flow a real stream of water out of the ground during wet weather, and even then it just might seep out. Otherwise, it is just a wet, kinda swampy spot most of the year.
If so, this one will still help feed your lake during all but the dryest of weather...
/ Creating a Lake #225
I guess I have kind of blown the moment, but HOW CAN I ATTACH A PICTURE TO A POST!!!
I am going to try it again. If it doesn't work can someone help a guy out?
Thanks.
Bryan
/ Creating a Lake #226
EddieWalker,
I'm with ya on the curiosity about the spring. I was hoping you were hitting a spring and not a drain! /forums/images/graemlins/frown.gif
this might help
Just looking at it quick it sounds like a running spring would be a source of water above a water table. If you are digging down and see level water that isn't rising, chances are you just hit a water table of sorts.
/ Creating a Lake #227
Eddie, if you are hitting gravel, that seems to indicate to me that sometime in the past there was probably a stream running through that area. It might still be an underground natural "french drain" of sorts. THe water could be caught in an underground bowl shape that is fed through the gravel layer and remains sealed by clay below the gravel.
This is just a very non-technical guess from a guy who doesn't have a clue. /forums/images/graemlins/laugh.gif /forums/images/graemlins/blush.gif
/ Creating a Lake #228
I know that water in the ground is in gravel or sand. My concern would be Drain. If the spring is not running I would cap with clay. Dig out like you have done and walk in some of that red sandy clay. Put a small crown and cut around. My father had some over on his place in Gary, TX. There was one big one a 40' x 60 ' area near were his dam was going the contractor moved the dam forward. He was worried about a leak. He came back a few years later and cut drains and tried to work that area. It became a real bog.
You might want to find a old local contractor and talk to them. When I was building mine I would have to unstop my drainpipe in the spring and drain then pump the soup bowl. I took SCUBA gear and a 2"running pump discharge. My two 4" drainpipes would be loaded and covered in clay and silt. When I would get them free it was amazing how much presser was on them with just 6' of water above. You could go on the backside of the dam and it would just be shooting out of the pipes. A gravel shoot like that might go to China. If water with presser was not coming out you might push in. Good luck and have fun.
John
/ Creating a Lake #229
My thinking is that you would be better off putting a nice laver of clay over the wet area and pack it down real good. The spring or water table might be a source of some water but its at the bottom of the lake. It also becomes a source for a leak. The level of the lake would then seek the level of the water table.
/ Creating a Lake #230
</font><font color="blue" class="small">( My thinking is that you would be better off putting a nice laver of clay over the wet area and pack it down real good. The spring or water table might be a source of some water but its at the bottom of the lake. It also becomes a source for a leak. The level of the lake would then seek the level of the water table. )</font>
I hadn't thought of the hydraulic pressure of the standing water on top of this... I was just thinking seasonal flow above the level of the lake.
I agree with this recommendation to try to plug it back up, if possible... Otherwise it might turn into a drain.
/ Creating a Lake
I am very concerned that it might turn out to be a drain.
Since I don't know what I'm doing or talking about, anything is possible. If it had stayed dry, then I'd fill it for sure. But since if filled up to a certain point, then I'm thinking the preasure from under ground is pushing the water out.
I put a stick at the water edge yesterday. This morning it's six inches deeper over a much larger area.
How much water preasure would the lake have? Would it be more than what's underground??
My current thinking is to wait and see what happens. If the water keeps rising to overflowing, then I'm thinking it's a good thing. If it stopes rising, then I'm still confused and unsure what to do. If the water level drops, then it's getting plugged for sure!!
My other concern is silt getting into the hole and filling it up if it is a spring. I would really like to keep it open if I can and it's benificial.
Once I clean up the mud around the hole, I'll dig a grench to divert silt that comes off from rain runoff and send it to another hole or a deeper part.
Eddie
/ Creating a Lake
Today is the first real rain we've had since Hurricane Rita, which was a tropical storm with she hit my area. My small 3/4 acre pond was dry, and so far it's up 2 feet!!!
I'm diverting most of the run-off for now until I'm done digging.
My plan for digging includes leaving underground islands to control the lily's. The top of the islands will be 4 to 4 1/2 feet below the surface when full. The sides are straight up and down and drop off three to four feet. This should put me well under the 6 foot depth that is about the max most lily's can survive. I'm also going to plant only those varieties that tend to behave themselves.
There are also severl dirt piles in this picture that will get hauled off in my dump truck, but for now will just stay out of the way.
Eddie
/ Creating a Lake
This picture is a view from the other side. The dirt on the right will be used to plug the dam when everything else is done. Until then, there is a break in the dam and a trench to drain off most of the water and allow me to keep digging.
Eddie
/ Creating a Lake
Here's a picture of Steph in one of my hunting jackets. She's standing in the middle of what will become my shoreline road. It's built up from the clay coming out of the lake. In time, I'll build a nice crown onto it and install about a dozen culverts.
Eddie
/ Creating a Lake #235
Eddie, did you say there is a road there? I can not get past that great gal in the camo...........Hey Steph. Glad to see you guys are still working on the place, it is really looking great. How goes the work on the house, anything really new there? Again great to see a post from you all............God Bless!
/ Creating a Lake #236
I think we have a place in the same general area, Elkhart. It's not funny that most of the lakes and ponds up there look about the same and they are not new. The rain was nice but we need about 30 more inches to fill them up.
Cool lake and even cooler watching the progress.
/ Creating a Lake #237
There was a time in my childhood where "fun" was to take a shovel and a wagon and dig as deep a hole as possible Naturally, I'd build a ramp for the wagon to haul my dirt loads out. Well, after a while I'd be 6ft deep and I'd get into the clay, the clay would continue and at about 8ft, I'd start hitting gravel. 10ft the iron "gravel" (little chunks of iron ore) would start getting thicker. After 10ft, I'd usually hit water and so the end of my fun in that particular hole, so off scouting for a new location. Of course when I was done with one hole, my grandpa would come along behind me and fill it in with the tractor.
Basically, I think you are just hitting the water table. The geology of the area should be simular to this area. We aren't too far apart, and the dirt layers look familiar.
/ Creating a Lake #238
</font><font color="blue" class="small">( It's not funny that most of the lakes and ponds up there look about the same and they are not new. The rain was nice but we need about 30 more inches to fill them up. )</font>
Oh. I thought lakes in Texas were filled with air.
In any case, be careful of what you wish for. Texas seems to be either dry or flooding.
Cliff
/ Creating a Lake #239
</font><font color="blue" class="small">( 10ft the iron "gravel" (little chunks of iron ore) would start getting thicker. )</font>
I have a friend up by Whitesboro who was digging a pond and came across iron gravel. He used it to pave a driveway. It was the nastiest lookin' stuff when it rained with all the running rust going down his hillside. /forums/images/graemlins/tongue.gif On the bright side, it worked and stayed in place pretty good too. /forums/images/graemlins/smile.gif
/ Creating a Lake #240
</font><font color="blueclass=small">(
Cliff )</font>
I guess you are trying to be funny Cliff. But I see that many of your posts have misplaced humor.
Being from the north I wouldn't expect you to know much about Texas. And yes ponds/lakes usually have water in them, not air. And many folks are doing more than wishing for rain.
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2023 John Deere 8R 310 Tractor (A63111)
2023 John Deere 8R...
DRAGON 500 BBL ACID TANK (A58214)
DRAGON 500 BBL...
2012 Ford E-450 Sewer Viewer Van (A61573)
2012 Ford E-450...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
