crown on driveway
   / crown on driveway #1
cisco
Platinum Member
L3410
I'm prepping out a single lane (15' wide, 3' shallow ditches on either side) 1000' dirt driveway on which I intend to place gravel. The dirt alone was adequate for infrequent personal use, in that I've only once in 3 years had to box blade a few loads of extra dirt on it to fill the shallow tire track grooves. However, a contractor is building a garage/apartment on the property in a few months, and that will mean a bunch more, and much heavier, road traffic - and once the abode is constructed, more frequent visits to the property by me. So, I'm going to apply Roundup and put a nice crown (again) on the driveway, and then gravel it once before the construction, let the trucks pound the new gravel into the roadbed, and then gravel it again. In theory, this should work - but probably won't, given my luck.
Anyhow, what sort of drop-off between the crown and side of the road should I shoot for, and does being a dirt/gravel road make any difference (vs. the current dirt alone)? And, as long as folks are feeling generous with advice, what size gravel should I use for the first and/or second applications?
   / crown on driveway #2
I do about 3" between the leading low edge of my blade and the high trailing edge, that seems adequate for this hard southern clay. I do have some problems with the shale that is underneath on reverse camber curves, in that I can't dig low enough to tilt the road the right way.
   / crown on driveway #3
SIR,
i would suggest you use gravel that is large for the first
time. it will go into the driveway, if there is heavy traffic,
and then you can use something smaller.
i had a problem in front of my place, and used 2inch clean
to start with. it disappeared, and then i had another load
on top of that. then i used 3/4 inch to top it off. it made a
good hard surface to drive on.
accordionman
william l. brown
wright city, mo.
   / crown on driveway #4
</font><font color="blue" class="small">( what sort of drop-off between the crown and side of the road should I shoot for )</font>
Rule of Thumb: ½” per roadway foot from crown to edge of road (not including road shoulder)
Ex. 15’ wide road, with crown in center, with 7 ½’ feet per roadway side = 3 ¾” rise over 7 ½’ from shoulder edge to crown center (or approximately 4 %)
   / crown on driveway
Got it. Thanks folks. Now, if that hurricane currently churning in the Atlantic doesn't come my way (coastal South Carolina), maybe I can make some progress next weekend. I've finished a weekend of bush hogging, and have switched over to the box blade.
Speaking of which, boy am I dumb. I had dropped the box blade on some uneven ground a few weeks ago (stupid trick #408 - don't ask about 1-407), and when I tried to put it back on the 3ph I couldn't simultaneously get both lifting arms aligned with the pins on the 500 lb plus box blade - until, and this took 15 minutes to figure out (during which I was sweating with a crowbar and hammer), I remembered that 1 of the 2 lifting arms was adjustable. DUH!
   / crown on driveway #6
Oh, that fact could make my life easier. /forums/images/graemlins/wink.gif
   / crown on driveway #7
)</font>
That would be great on a hard surface road that is shedding water.. gravel is so porous that water will be traveling beneath the substraight... it will be like an aquifer... I'd go flat.. besides.. it'l crown on its own with traffic.. and he'll have to blade that out as well.
Soundguy
   / crown on driveway #8
We used 3" crusher run spread flat, it crowned itself. Actually needed to drag some from the middle to the edges several times. We still need to top it but have been waiting until the heavy trucks like cement, lumber, septic, etc.. are all done, almost there!
   / crown on driveway #9
I would strongly suggest that you DO crown the roadbed. WHile you will get settling in the tracks, those tracks will be the low points, and you will have 2 little creeks on your driveway. If you want it to shed water, crown it! Also, if you have any clay in your road, you want to start with something much bigger, like 4 inch, especially if your contractor will be building this fall (rainy season) and driving anything like a tri-axle dump even once or twice. THese heavy trucks will really roll it in, and then you could spread the 2 inch crusher run and crown that.
Up here in the Northeast, we get some really soft ground in the spring after the winter thaw. We had a large addition built, and got a tri-axle dump stuck up to its axles /forums/images/graemlins/crazy.gif Had to tow it out with a track hoe /forums/images/graemlins/shocked.gif After that, the contractor said he needed to lay the 4 inch stuff (sometimes called cobble, or rip rap). This just lay on the road for the rest of the spring and summer. It was really bumpy, but I could crawl over it in a Saab 9000 without too much trouble. Now I have a really solid driveway taht only needs re-crowning every 4 years or so. That rip rap is now at least 8 inches down formthe top, just by churning and heavy traffic.
   / crown on driveway #10
</font><font color="blue" class="small">( would strongly suggest that you DO crown the roadbed. .. If you want it to shed water, crown it )</font>
With respect... I do this for a living... a pile of gravel isn't going to shed water.. it is going to be a medium for the water to travel in ( the voids in the gravel ). The shape of the final non-porous road bed under the gravel will make more of a difference on the flow characteristics than the large consolodated 1/2" and 3/4" gravels. The exception will be gravel fines and 1/4 to 3/8 material, that when saturated, will flow differently due to less /smaller voids.
His gravel road will self crown quickly.. and yes, it will rut... he'll have to drag/blade that out anyway... no need to start with an existing crown, as it will still rut at the same rate.. except he'll have more drag/blading to do.
Soundguy
2007 Chevrolet Impala Sedan (A55853)
2007 Chevrolet...
Cushman Cart (A55853)
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
2025 ZWB 59in Excavator Boom Mini Skid Steer Attachment (A53421)
2025 ZWB 59in...
60" ORANGE PIN ON BUCKET (A57192)
60" ORANGE PIN ON...
2016 Godwin CD150M 6in Dri-Prime Pump S/A Trailer (A54811)
2016 Godwin CD150M...
