Crusher run under pole barn
   / Crusher run under pole barn #1
aarolar
Platinum Member
Augusta Ga
Kubota MX4800
Looking for advice for putting crusher run under my 30x60 pole barn I use for equipment storage. Right now I only have about 4" clearance on my ROPS right now so I need to remove dirt first. For this particular application can I simply remove 6" of soil then add back 4" of crusher run?
   / Crusher run under pole barn #2
You can do that. Nothing like a concrete slab, but I know the costs.
Anyway, I suggest using 3/4" minus gravel (crushed) and then a plate compactor over the
whole surface. It is amazing what proper compaction will do.
   / Crusher run under pole barn #3
I would dig out under the door and pour a concrete footer the length of the door about a foot wide. Then it acts like a edging for the rock. Plus after years of going back and forth over it, it won't build up with dirt and risk hitting your ROPS.
No door on this just a wide open pole barn.
   / Crusher run under pole barn #5
Another vote for the 3/4 minus. It makes a pretty good floor if you don't have the money for concrete. It is what I have in my "Kioti den"
   / Crusher run under pole barn #6
Crush and run is about the same as gravel but hardens somewhat and packs better than plain gravel.
I get it at 42$ per ton locally. Good stuff.
Where at in GA Joe?
   / Crusher run under pole barn #8
Farm is south central and home is coastal GA.
   / Crusher run under pole barn #9
It is quite a bit cheaper here, $110 for 7 tons. It was $120 when gas was higher.
   / Crusher run under pole barn #10
You shouldn't have any problems using it, I'm using inch minus in my cold storage part of mine.
2013 FORD F250 (A60460)
2013 FORD F250...
SKID STEER ATTACHMENT HAMMER (A58214)
SKID STEER...
Milwaukee Red Zone Tin Sign (A57454)
Milwaukee Red Zone...
2003 Komatsu WA250-3MC Articulated Wheel Loader (A56857)
2003 Komatsu...
McFarlane 4030 Reel Disk (A59814)
McFarlane 4030...
2003 Big Tex 10PI...
