Crusher run under pole barn
   / Crusher run under pole barn #1
aarolar
Platinum Member
Augusta Ga
Kubota MX4800
Looking for advice for putting crusher run under my 30x60 pole barn I use for equipment storage. Right now I only have about 4" clearance on my ROPS right now so I need to remove dirt first. For this particular application can I simply remove 6" of soil then add back 4" of crusher run?
   / Crusher run under pole barn #2
You can do that. Nothing like a concrete slab, but I know the costs.
Anyway, I suggest using 3/4" minus gravel (crushed) and then a plate compactor over the
whole surface. It is amazing what proper compaction will do.
   / Crusher run under pole barn #3
I would dig out under the door and pour a concrete footer the length of the door about a foot wide. Then it acts like a edging for the rock. Plus after years of going back and forth over it, it won't build up with dirt and risk hitting your ROPS.
No door on this just a wide open pole barn.
   / Crusher run under pole barn #5
Another vote for the 3/4 minus. It makes a pretty good floor if you don't have the money for concrete. It is what I have in my "Kioti den"
   / Crusher run under pole barn #6
Crush and run is about the same as gravel but hardens somewhat and packs better than plain gravel.
I get it at 42$ per ton locally. Good stuff.
Where at in GA Joe?
   / Crusher run under pole barn #8
Farm is south central and home is coastal GA.
   / Crusher run under pole barn #9
It is quite a bit cheaper here, $110 for 7 tons. It was $120 when gas was higher.
   / Crusher run under pole barn #10
You shouldn't have any problems using it, I'm using inch minus in my cold storage part of mine.
Case 1020 25ft Draper Head (A56438)
Case 1020 25ft...
2020 Case CX80C Excavator (A59814)
2020 Case CX80C...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
TANK MANIFOLD (A55745)
KOMATSU PC490LC-10 EXCAVATOR (A60429)
KOMATSU PC490LC-10...
JOHN DEERE 7210 TRACTOR (A60430)
JOHN DEERE 7210...
