CT225 no start
   / CT225 no start #11
Wire brush where the negative cable attaches to the tractor frame until it is shiny bare metal. Replace the original bolt/screw that attached the neg cable to the frame and clean the negative cable end to bare metal too. Cut a slice through the plastic jacket of the neg cable, close to it's frame end connector and look closely for any corrosion presence. If there is corrosion inside the cable jacket - replace the entire cable. Also get some battery post protection spray and spray ALL cable ends and post attachments, then reassemble the neg cable to the frame and spray that area until it is thoroughly covered in the protective coating. make sure both battery posts are shiny metal clean before assembly of the cable connectors.
2021 MULTIQUIP 25 WHISPERWATT AC GENERATOR (A59823)
2021 MULTIQUIP 25...
2024 CATERPILLAR 930 AG HANDLER WHEEL LOADER (A52709)
2024 CATERPILLAR...
2021 Ford F-150 Ext Cab 4X4 Pickup Truck (A55852)
2021 Ford F-150...
2009 CAROLINA  16FT EQUIPMENT TRAILER (A58018)
2009 CAROLINA...
Club Car Carryall Electric Utility Cart (A55851)
Club Car Carryall...
2017 Ford F-550 4x4 Ext. Cab Mason Dump Truck (A59230)
2017 Ford F-550...
