Cub Cadet 8454 Any info helpful...
   / Cub Cadet 8454 Any info helpful... #1
Roper14
For starters - I am like everyone else I want the most bang for my dollar, I just don't really like spending a whole lot of 'em -
I've got about 30 acres of hay pasture that will be bushhogged at some point (it is being hayed currently - only have to mow about 3-4 acres now - but you never know when the hay will dry up) dirt work - pulling a 500 gallon drawbar sprayer..etc...typical tractor work.
I ran across a Cub 8454 and after reading a "little" about it I am considering looking into the tractor (a painted Kioti as everyone says) - My question what type of luck does everyone have out of these tractors? And what type of $$$$ should I expect to pay (I have operated all the major colors, but none of the second tier tractors(no offense)....but I have noticed that the gap seems to be closing...(as the upper tier is getting worse--JD 5103 for example---different story).........
Sooo. Any thoughts. tractor has around 400hr - 4wd - fel and r4 tires (wish r1) asking around 12-13K seems a little high to me - yet I could not find any comparisons on the net - just a Kioti 35 in the local newspaper running for about a month for 8500 (same setup) - I would think that it may be " too small"
lastly------dealer said he had to fix the shuttle shift---should I expect more issues...if so- the search continues:cool:
   / Cub Cadet 8454 Any info helpful... #2
The new Compact Tractor Guide says retail for an '04 or '05 runs from $12,000 to $16,000 so your dealer seems to be right at the low side.
I appreciate the $$ info. I spoke with a friend who actually owns an 8454 - he said new they cost around 22-23, but they do not even sell these tractors any more (cub doesnt). He said the one thing to possibly look out for - apparently Kioti had some issues with the 4wd on the k45 when they were making the 8454 - there were apparently 4-5 changes to the 4wd before "kioti" fixed the problems they were having (the 4wd going "out") - everything apparently is fine in the k45 now....thanks again for the input
F-150 Running Boards (A57454)
F-150 Running...
1998 IMT EZ Hauler Mini Crane with Trailer (A57453)
1998 IMT EZ Hauler...
(14) Dumbells with Weight Rack (A57454)
(14) Dumbells with...
2004 Freightliner FLD120SD Day Cab Truck, VIN # 1FUJALCK54DM74906 (A57453)
2004 Freightliner...
Cushman Electric Cart (A55851)
Cushman Electric...
2009 Landoll 435A Trailer (A60460)
2009 Landoll 435A...
