CULTIPACKER--NEED INFO
   / CULTIPACKER--NEED INFO #1
Case485Guy
Corpus Christi. Tx
Case 485
OK from what I have read, most seeds recommends firm seed beds and a cultipacker is the answer, right?
Very sandy loam soil to plant haygraiser/pasture grass etc. will be spread from broadcast seeder.
Any recommendation's? tips? advice?
Once again I don't know much about this, but willing to learn.
   / CULTIPACKER--NEED INFO #2
A cultipacker will minimize runoff and help the seed germinate. We make our own Everything Attachments Culipackers here in NC and ship them free to a business or supporting freight terminal within 1,000 miles.
Here's a video we made of a cultipacker in use.
Travis
   / CULTIPACKER--NEED INFO #3
Hay/grass seeds are very small; yes, a Cultipacker is your best tool to insure small seed germination after a light scuffing of soil in preparation, or maybe "slitting" soil shallowly with front and rear disc harrow gangs adjusted fore and aft, NOT set on an angle to throw dirt to the sides.
Larger seeds do better with deeper soil prep to support deeper root structures and planting at depth three times seed diameter { 1" +/- }, then covering with SOMETHING (four linked tires, disc harrow/shallow, drag harrow, rotary harrow, 6 X 6 timber wrapped in chain link fence ) and optionally Cultipacking if you have the time and energy.
Having written this, I have good luck with mixed size food plot seed, which I hand sow over disced ground, then Cultipack.
Like you, I have sandy soil. The Cultipacker presses soil around the seeds, eliminating air, retaining water.
Note mixed seed sizes in Photo №3. Soil is black because it is fill from a burn pile where I was filling in a small washout.
Cultipacker is from.....guess??????......Everything Attachments.
2018 KOMATSU WA320-8 WHEEL LOADER (A60429)
2018 KOMATSU...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
2017 BX2680 Sub Compact Utility Tractor (A56438)
2017 BX2680 Sub...
2012 PROCO 130BBL VAC TRAILER (A58214)
2012 PROCO 130BBL...
2019 KOMATSU D155AX-8 CRAWLER DOZER (A60429)
2019 KOMATSU...
