Dam scoop DIY plans
   / Dam scoop DIY plans #22
That is pretty much what my $300 one is like.
so you got a steal deal...
When a 1700kg compact pulls 2.5 yard (or 1.9m3) like in that video, my 3.5 ton 5718 should pull a 4m3 (5.5 yard) scraper, so when i rent it to a local (less skilled) farmer he can handle it nicely with a 4.5 ton 100hp 4wd... Within now and 15 years i'll build one, when everything else i want to build has been built...
   / Dam scoop DIY plans #23
Re Video.
The Ashland 25S appears to be a well engineered scraper, have always liked it when only one set of hydraulics is required.
I was not impressed by the video implication that a 2.5 cu/yrd scaper could be handled by a 40HP compact tractor, looking at the operation,
it could be seen that the material was soft, a very shallow cut was being taken and the scaper was not being loaded to capacity.
From my own experience a 1 yard scraper would be enough for a tractor of that size, once in the real world.
   / Dam scoop DIY plans #24
   / Dam scoop DIY plans #25
This is the one I found.[/url]
that tractor should have no problems filling it within a tractor length... when using one for land levelling here, it would only scrape thin layers on a hundred yard length which requires less traction. Contractors are using way bigger scrapers for land levelling, an 11m3 pulled by a 10 ton NH T8.330 is a bit less than a ton per m3 (about a metric ton per yard) . Most people think Holland is totally flat, but yet farmers here wish it to be millimetered as a billiart table:
https://www.youtube.com/watch?v=IzX1poMZR_g
24FT Enclosed Trailer (A53424)
24FT Enclosed...
2012 Club Car Carryall 1 Utility Cart (A54811)
2012 Club Car...
UNUSED CFG INDUSTRIAL MX15RX EXCAVATOR (A52706)
UNUSED CFG...
2012 Hitachi PC138 (A47477)
2012 Hitachi PC138...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55301)
Michelin CARGOXBIB...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A53426)
2019 INTERNATIONAL...
