DAMAGE DUE TO REAR WHEEL SPACERS
   / DAMAGE DUE TO REAR WHEEL SPACERS #11
Oh my JD, I can mount the rear wheel reversed and it gives you more width. Is that the case with Kubota as well? Obviously the directional tires would be an issue but...
   / DAMAGE DUE TO REAR WHEEL SPACERS #12
It depends on which wheels you have, the welded one piece rims aren't intended to be reversed, the two-piece AG style rims are.
Chilly
   / DAMAGE DUE TO REAR WHEEL SPACERS #13
I have 2" front and rear and have had no problems. I did have to adjust the steering stops on the front end when the 60" MMM is mounted.
   / DAMAGE DUE TO REAR WHEEL SPACERS #14
Ive been watching this thread ,and now i want everyones honest opinion.Do you think id be ok with wheel spacers,even with the added weight of my homemade cab.Alot of you know i work this bota hard,hauling rocks,hauling logs etc. What do you guys think?
ALAN
   / DAMAGE DUE TO REAR WHEEL SPACERS #15
ALAN
For what it's worth, I've had BXpanded's wheel spacers on the front and back of my BX24 for 2 years. I have the BH on just 20% of the time but I work this little machine pretty hard and no problems so far. Machine has 200 hours and spacers have about 125-150 hours I would guess.
   / DAMAGE DUE TO REAR WHEEL SPACERS #16
I have the Brotek spacers and no problems after (maybe 50) hours so far...very stable on hillsides...great addition!
   / DAMAGE DUE TO REAR WHEEL SPACERS #17
I don't want to threadjack this, but, on a tractor, there is no stability gained by widening the front wheels. The reason why many tractors have that option, are to allow for different crop widths.
   / DAMAGE DUE TO REAR WHEEL SPACERS #18
I'm glad to know this, thanks.
   / DAMAGE DUE TO REAR WHEEL SPACERS #19
If you say so, but I don't buy that in all cases about stability.
Maybe widening the front only (and not the rear) by an inch on both sides wouldn't help, but I will make the dumb assumption that what ever you do width wise to the rear you should do to the front on a tractor.
At least then in 4WD drive the wheels would be following the same travel lane as before without the spacers.
   / DAMAGE DUE TO REAR WHEEL SPACERS #20
Another bump of an older thread to see if anyone had any problems.....
2838 (A58376)
2838 (A58376)
New/Unused CFG Industrial MX12RX Mini Excavator (A57453)
New/Unused CFG...
2015 Ford F-350 Versalift Bucket Truck (A56858)
2015 Ford F-350...
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
7021 (A55851)
7021 (A55851)
2019 CATERPILLAR 289D SKID STEER (A52709)
2019 CATERPILLAR...
