My Hoe
Platinum Member
- Joined
- Oct 31, 2010
- Messages
- 560
- Location
- NYS--Various Parts
- Tractor
- Kubota B3000HSDCC, BH77, 5' Belly Mower, 6' Hyd. Angle Plow
sixdogs said:
Kubota refreshed their BX series recently. They went from the 60 series to the 70 series. For example, the BX 2360 is now the BX 2370. In doing so they renamed the BX25 into the BX25D. There are a half dozen or more changes such as different seat and change in steering wheel but the most significant is the change in placement of the hydro pedals. There is no difference in horsepower or lift capacity so both the BX25 and BX25D will perform quite similarly. If the new features are important to you then seek out a BX25D. If not, a BX25 will do nicely. Whatever you do, make sure you are getting what was advertised, the new numbering system from Kubota has created confusion. Don't expect a used tractor salesman to know the differences unless it is a Kubota dealer.
Sent from my iPad using TractorByNet
I have two points on the bolded text, above.
1. I am not aware of a change in the hydro pedals (so please educate me) but Kubota DID put the brake on the LEFT side. I think this is a first for ALL of Kubota's SCUTS and CUTS, which (I believe) historically all had the brakes on the right side, jammed in behind and above the hydro pedals. However (to my knowledge), only the B-series and larger have split brakes--not the SCUTS. So, the B's have split brakes, but without the (sometimes not-available and usually-only-optional "cruise control" on the B-series), split brakes seem largely useless, as you can't keep one foot on the hydro pedal AND switch between Left and Right brakes--unless your B-series (and larger) has the optional cruise control. Therefore, even though the new "BX25d-D" does have cruise control (per an early, dealer promo piece, seen here: Kubota Dealer Meeting 2012 - New BX1870 BX2370 BX2670 & BX25D) since I do NOT believe ANY BX has "split brakes," unlike the larger B-series, I can't see why (finally!) moving the brake pedal to the left is any big advantage. Because, without split brakes, which can be used to steer from the rear wheels (used in bottom-plowing, for example) I don't know why it would matter which side the brake pedal is on, as most hydro owners (here) say they almost never even touch the brake--they just let go of the hydro pedal. So the new brake location seems like it's a NOT a big deal, unlike this:
The NEW BX25D (with the "D" not only on the metal data tag, down on the frame, but also--and for the first time--in a decal "call out" on the FEL arms) also has:
2. A QUICK ATTACH for the FEL!
This is a big deal (for me) even though it is still just a proprietary Quick Attach, as opposed to an SSQA-type or "universal" QA.
Why is this a big deal?
Because, to buy an aftermarket QA is $825. from ATI. To get the original bucket's ears "shaved" off and the female QA plate attached is $200.-300., I'm told, from a fab shop. Adding in the shipping, and repainting of the bucket (after the QA surgery) and you're up about $1,200. (plus tax). (Not to mention that, AFAIK, no aftermarket mfr. even offers a SCUT-sized SSQA, meaning the [roughly] B-sized SSQA from ATI is unnecessarily-heavy, and would eat [unnecessarily-deeply] into the already-limited lifting ability of the BX25D's FEL).
So the QA, IMHO, is the single, biggest change in the two BX25's.
If I had to mention the second most significant change, for me, it would be that the hoe now has the thumb bosses built into the dipperstick, for positive location of a thumb (which I believe Kubota also offers, for the first time, in their SCUT). This is a big deal, as I am not a fan of the "clamp on" style of aftermarket thumbs, as I've read they tend to slip. Just my opinion--YMMV.
On the OP's original question: if I were in the SCUT market (as I briefly was, twice) I'm sorry, but there's NO WAY I could have missed the presence or absence of a Quick Attach, as I would want to use the forks and bucket, interchangeably, frequently. Again, to me, that's the single, biggest improvement in the "BX25d-D".
Therefore, if the OP really wanted that, he should have looked for it. Which is not to say that he shouldn't at least attempt to back out of this deal, if it's not for him. IMHO, he'd do well to do so, as others have said the deal he got was only so-so (and others have said he did well).
It can't hurt to ask to be let out of the deal, but I would never expect the dealer to kick back some money (if he wanted to keep the tractor), when they can expect to get their full price from the next customer who walks in. Either get out while you still can, for no loss (other than transportation, time and anxiety) or live with it. Personally, I'd want out, and go buy a new one, for "Zero/Zero + Warranty," as opposed to this machine.
For me, the most amazing thing about this 12+-page thread is that almost no one (with one, other exception) seems to feel that absence of the QA on the FEL is a big deal. For me, again, the ability to switch from bucket to forks, in mere minutes, without greasy aggravation, makes this handly, little machine more than TWICE as handy. I can't help but see it as a built-in, $1,200.+ option.
In fact, the new QA feature almost swayed me to buy a new "BX25d-D". But I need the ground clearance of a B, and like some of the B's other features more than the BX's. But the convenience of having the QA right there, from Day 1, with no fab shop hassles (as I don't trust my welding "skills" to that extent) is a big deal, IMO. (I do believe Kubota now offers some B's with an optional SSQA, but I'm in the used market, for different reasons).
