Decompression control
   / Decompression control #1
FL_Jerry
FL, Bay County
YM 2000
Is the Decompression mechanism an on off device or does it release in steps? The reason I ask is mine (2000BD) sticks a little on release a the very top sometimes. It's not the handle/cable as I disconnected the assy to check it out.
Jerry
Jerry
   / Decompression control #3
"Is the Decompression mechanism an on off device or does it release in steps? The reason I ask is mine (2000BD) sticks a little on release a the very top sometimes. It's not the handle/cable as I disconnected the assy to check it out."
I'm not sure I understand your question. It opens the valves a little or a lot depending on how far you pull the lever. I have to push mine back in to release it.
   / Decompression control #4
I was trying to ask if it is like a light switch, on or off but nothing between, or if it was like a volume control, i.e. digital or analog. I think you answered my question:)
When I push the lever back in, it sometimes doesn't return to the end of its travel. From what you told me, I'll check the lever assy again.
Thanks
Jerry
Thanks
Jerry
   / Decompression control #7
It is full on or full off. Don't use it to kill your engine. It is used to help start the motor not kill it.....
   / Decompression control #8
yeah, I was just concerned that it wasn't returning to the off position all the way. If it is full on/off, then it doesn't matter as there isn't an in between. Thanks for the input.
Jerry
Jerry
2017 DITCH WITCH RT30 (A51243)
2017 DITCH WITCH...
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2020 KUBOTA RTV X1100C UTV (A51406)
2020 KUBOTA RTV...
2015 JLG G12-55A 12,000lb 4x4 Rough Terrain Telehandler (A49461)
2015 JLG G12-55A...
TOOLBOX/FUEL TANK COMBO (A50854)
TOOLBOX/FUEL TANK...
MAHINDRA 2816 TRACTOR (A51243)
MAHINDRA 2816...
