Decompression control
   / Decompression control #1
FL_Jerry
FL, Bay County
YM 2000
Is the Decompression mechanism an on off device or does it release in steps? The reason I ask is mine (2000BD) sticks a little on release a the very top sometimes. It's not the handle/cable as I disconnected the assy to check it out.
Jerry
Jerry
   / Decompression control #3
"Is the Decompression mechanism an on off device or does it release in steps? The reason I ask is mine (2000BD) sticks a little on release a the very top sometimes. It's not the handle/cable as I disconnected the assy to check it out."
I'm not sure I understand your question. It opens the valves a little or a lot depending on how far you pull the lever. I have to push mine back in to release it.
   / Decompression control #4
I was trying to ask if it is like a light switch, on or off but nothing between, or if it was like a volume control, i.e. digital or analog. I think you answered my question:)
When I push the lever back in, it sometimes doesn't return to the end of its travel. From what you told me, I'll check the lever assy again.
Thanks
Jerry
Thanks
Jerry
   / Decompression control #7
It is full on or full off. Don't use it to kill your engine. It is used to help start the motor not kill it.....
   / Decompression control #8
yeah, I was just concerned that it wasn't returning to the off position all the way. If it is full on/off, then it doesn't matter as there isn't an in between. Thanks for the input.
Jerry
Jerry
(2) 15X8 RIG MATS (A50854)
(2) 15X8 RIG MATS...
3in Poly Pipe (A49461)
1987 FORD 2110 TRACTOR (A51222)
1987 FORD 2110...
20 STEEL FLAT SHEETS (A50854)
20 STEEL FLAT...
2013 FOREST RIVER WILDWOOD BUMPER PULL CAMPER (A50854)
2013 FOREST RIVER...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
