Deer Fence Design
   / Deer Fence Design #11
Deer can jump high (over 8 feet) and they can jump wide but they can't jump high and wide at the same time. Horizontal extensions of lightweight material at the 8 ft level at the top of a conventional fence will discourage deer.
Electric fences up in the air won't do the trick as the deer can't touch the ground and the hot wire at the same time.
I have seen deer crawl on their bellies under the bottom wire of a 5 wire barbed wire fence instead of jumping the 4 1/2 foot fence and other times clear an 8 ft fence.
To keep critters (all critters big and small but not winged) out of the garden can be done but requires a fence with close spacing for the first few feet and must be tall.
There are outfits selling the materials for making horizontal extensions on the top of fences to deter deer. These are not so much a physical barrier as a visual one. If it looks too high and wide to jump the deer will not challenge it.
Pat
   / Deer Fence Design #12
I have a neighbor who has a garden each year that looks like it's out of a magazine. I've looked at his settup as I drive by and here is what he does.
He uses the standard T-Posts for the main fence. He has electric fence starting about 6 inches off the ground then the spacing get progressively bigger as he moves up. I think he has about 4 rows or electric fence. He then places 4 or 5 ft. PVC on top of each of the T-Posts and puts a couple of lines of cloth around the top section. I'm guessing the top part is to keep the deer from jumping in and the bottom keeps the "critters" out. If I ever get around to putting a graden in again this is the plan I will follow.
Wedge
   / Deer Fence Design #13
Wedge
I too have a neighbor with a garden every year right out of a "Better Homes and Gardens" photo layout. He has no fence at all around it. A couple years ago he had a problem with cantaloupe disappearing the night before he planned to pick them the next morning. After several occurrences he staked it out and shot 3 dogs.
I have no clue why he doesn't have deer problems as it is not for a lack of deer. His place is right at a frequently used deer crossing on the highway.
There is no single right answer.
Pat
   / Deer Fence Design #14
You also have to watch the nearby elevation - I have seen deer choose the up slope near a fence to clear twelve feet of fencing beside a conveyor system to get at the nice grass beside it. They would then run along the beside the conveyor until the slope was the right way to exit.
Sudden onset lead poisoning (which occurs when 150 grains of lead hits the animal at about 2600 fps) is a very effective way of stopping dear in the garden (if legal of course) !!!
   / Deer Fence Design #15
It took 11 posts to get to this. :D :D Patrick is the man!
8' will usually do the trick, around here you see the big (as in tall) T posts with some 6x6 hog wire. More at the bottom if you want to keep the small stuff out.
If a deer is on the run or spooked they'll take a shot at a high fence. But in my hunting years when they were just out for a meal, they'll walk through a 5 wire fence 75% of the time, 25% they'll crawl under.
Rob
   / Deer Fence Design
Pat
That is an excellent point, Pat. I'll have to rethink the placement of the electric wire if I use it at all. It's hard to beat the price of electric fence, though.
tallyho8 said:
If those 3x5 posts are landscaping timbers, they usually have a very light pressure treatment and will not last more than a few years as posts. You would be much better off using 4x4s which are more heavily preserved.
That's interesting and disappointing. I would have guessed that pressure treated is pressure treated. Those timbers are half the cost of a standard 4x4.
Robert_in_NY said:
I agree with what chatcher is getting at. A 3 board fence looks nice but it will do nothing to keep rabbits, coons and other varmits out of your garden. Unless you are going to put fenceing behind the 3 board. A 2x4 fenceing maybe with a finer mesh along the bottom to keep the rabbits out. And keep the fence line clear of all weeds so you can see if something is trying to dig under (you could lay some chicken wire along the ground to discourage digging but that would be up to you).
I like the idea of putting a smaller mesh on the bottom. I haven't seen rabbits but I haven't been lookin either. Coons are around for sure.
Do you mean PVC pipe stuck over the top of the post or a PVC mesh fence? I am having a hard time visualizing this. Intriguing because it could be a very low cost alternative to wood.
Thanks everyone for the input. These are some great insights that I never would have thought of without a lot of trial and error.
Long live TBN!
~Nate
   / Deer Fence Design #17
You just have to run a hot and a ground wire up high. They touch both when they jump up and get zapped. Would love to see a video of that!
One of the locals here just has a short electric fence. He only turns it on at the beginning of the season until the deer learn. He uses peanut butter on aluminum foil hanging on the wire to teach!
   / Deer Fence Design #18
Nate, all I might have said has already been said.... when you find the perfect answer, post it and you'll become famous:D
   / Deer Fence Design #19
From what I've seen up here in Maine, a two fence system works well. Basically, have two parallel fence lines spaced six feet apart at about 3' off the ground. I've even seen this using only single wire fences. Apparently, the deer will jump one fence no matter what, but they don't like to be stuck between two. I've also heard that you sort of have to train the deer by putting pieces of foil on the wire and bait it with peanut butter. (Oh, I see mjfgox6 pretty much posted the same thing.)
The downside is that you have a six foot wide perimeter that needs to maintained between the two fence lines. Electric fence is a psychological barrier, not a physical one!
I've seen a stuffed coyote be quite effective for geese as well. I like the idea of buying the 3d coyote target.
-Justin
   / Deer Fence Design #20
To me you want to deter them from trying to jump. Once one jumps in (or maybe a dozen jump in!!!) then you have deer that won't jump out!! :D :D
19015 (A53422)
19015 (A53422)
2021 FORD F-150 STX (A55745)
2021 FORD F-150...
2016 Ford F-550 4x4 Ext. Cab Service Truck (A53422)
2016 Ford F-550...
1999 Kubota L2500D Utility Loader Tractor (A55851)
1999 Kubota L2500D...
Year: 2005 Make: Ford Model: Explorer Vehicle Type: Multipurpose Vehicle (MPV) Mileage: Plate: Body (A55788)
Year: 2005 Make...
