Device for checking 7 blade trailer lights WITHOUT vehicle - anyone know of one?
   / Device for checking 7 blade trailer lights WITHOUT vehicle - anyone know of one? #21
I have the Ranger MUTT by IPA. Comes with the adapters and everything except battery. Less than $200 and self contained, so works out in the field or were ever.
Patrick
Any recommendations on brand of plugs to use for rewiring?
/edit - I'm referring to the 7 blade trailer plug.
   / Device for checking 7 blade trailer lights WITHOUT vehicle - anyone know of one? #23
Here is the IPA Tools tester for light duty trailers and RVs. As is everything else it is on backorder.
   / Device for checking 7 blade trailer lights WITHOUT vehicle - anyone know of one? #26
New option, sellf-powered, comes with case, ~$160,
  • Digital voltmeter
  • 20 ft. jumper lead set
  • Bad ground indicator and continuity tester
  • Positive/negative voltage indicator
  • Relay and component tester
  • Voltage and polarity testing
  • Continuity testing
  • Activating components out of the vehicle’s electrical system
  • Activating electrical components in the vehicle
  • Activating electrical components with ground
   / Device for checking 7 blade trailer lights WITHOUT vehicle - anyone know of one? #27
The heavy duty one on Amazon with the junction box
   / Device for checking 7 blade trailer lights WITHOUT vehicle - anyone know of one? #28
Do LED trailer lights work fine on 12v AC?
Yes they will, since they are diodes, they will conduct on half the AC wave.
   / Device for checking 7 blade trailer lights WITHOUT vehicle - anyone know of one? #29
OT, but I've heard that some LED headlamp replacements can cause havoc within car wiring somehow. There's a ballast or current limiter .. something that fixes/prevents issues. I'm sure any 'test boxes' we can buy RTR wouldn't have issues with LEDs.
btw, I've found a DC component more than once testing AC devices that acted up. The DC scale on a VOM is all that's needed. AC setting/range can also find AC in DC circuit, say pointing to a bad diode in a generator.
OK back to OP's ... uh .. pics? Links?
Well after Amazon messed up on two deliveries I chickened out fter reviewing it on youtube I ordered a MUTT from IPA via Northerntool.
Then today after looking it up again on Youtube 5 DIY solutions show up.
The correct key words seem to be "trailer light tester".
So enjoy:
Still surprised eTrailer didn't have a moderate cost solution.
2016 Club Car Carryall 710 Electric Utility Cart (A55851)
2016 Club Car...
2007 OVERLAND  TANK TRAILER (A53843)
2007 OVERLAND...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
2011 Ford E-250 Super Duty Cargo Van (A55852)
2011 Ford E-250...
UNUSED 1RANCH 1RGPM GROUND PROTECTION MATS (A57193)
UNUSED 1RANCH...
CFG Industrial H15R (A56469)
CFG Industrial...
