DF-354 : Hydraulic fluid fill point, drain point, and liquid level?
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level?
Hi Chris,
I know exactly the cylinder you're describing!
So....I gather that the 'filter' inside this cannister is probably more like a screen?
Mike
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #12
Correct. Once removed from the "cannister", the filter will consist of a screen wrapped around a permanent central core. Keep the core, replace the screen. I have a similar system on my two tractors, and buy 80x80 micron brass screen by the running foot. From this bulk stock, I then cut replacement pieces to wrap around the OEM core
//greg//
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #14
That'll work just fine. But note the manufacturer. You're going to pay a premium for the yellow bucket and NAPA logo. I'm betting you'll find it cheaper under the actual Coastal brand, sold around here by Advance Auto Parts, O'Reilly's, AutoZone, etc.
//greg//
Ah haaaa....
Good detective work Greg!
I'll check out a few other suppliers before I cough up the big bucks.... :)
Mike
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #16
We buy a the brand I showed in the earlier post for some of my equipment. Its called Extreem and runs $26.99 for 5 gallons just to give you a base line on price.
Chris
Thanks Chris!
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #18
Most WallMarts carry that UTF in 5 gallon buckets too.
Don't remember the price but I think it's pretty close to what Chris said. I know it's less expensive than the Napa stuff.
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #19
You guys have helped me so much by reading these threads I joined up! I like to be sure of what I am doing when working on my tractor because I have had some bad luck!
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #20
I have the same tractor as you the screw in plug dipstick reads 2 do I add fluid? I heard you gust fill it up to top is that correct?
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2022 Polaris Ranger Utility Cart (A55788)
2022 Polaris...
2013 Ford F-150 Pickup Truck (A53422)
2013 Ford F-150...
2017 Ford Transit 350 Handicapped Van (A55788)
2017 Ford Transit...
Jumper Cables (A53316)
Lockwood 480 Pecan Harvester (A55301)
Lockwood 480 Pecan...
