DF-354 : Hydraulic fluid fill point, drain point, and liquid level?
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level?
Hi Chris,
I know exactly the cylinder you're describing!
So....I gather that the 'filter' inside this cannister is probably more like a screen?
Mike
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #12
Correct. Once removed from the "cannister", the filter will consist of a screen wrapped around a permanent central core. Keep the core, replace the screen. I have a similar system on my two tractors, and buy 80x80 micron brass screen by the running foot. From this bulk stock, I then cut replacement pieces to wrap around the OEM core
//greg//
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #14
That'll work just fine. But note the manufacturer. You're going to pay a premium for the yellow bucket and NAPA logo. I'm betting you'll find it cheaper under the actual Coastal brand, sold around here by Advance Auto Parts, O'Reilly's, AutoZone, etc.
//greg//
Ah haaaa....
Good detective work Greg!
I'll check out a few other suppliers before I cough up the big bucks.... :)
Mike
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #16
We buy a the brand I showed in the earlier post for some of my equipment. Its called Extreem and runs $26.99 for 5 gallons just to give you a base line on price.
Chris
Thanks Chris!
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #18
Most WallMarts carry that UTF in 5 gallon buckets too.
Don't remember the price but I think it's pretty close to what Chris said. I know it's less expensive than the Napa stuff.
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #19
You guys have helped me so much by reading these threads I joined up! I like to be sure of what I am doing when working on my tractor because I have had some bad luck!
   / DF-354 : Hydraulic fluid fill point, drain point, and liquid level? #20
I have the same tractor as you the screw in plug dipstick reads 2 do I add fluid? I heard you gust fill it up to top is that correct?
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A53843)
2013 XLR...
Year: 1999 Make: GMC Model: C7500 Vehicle Type: Truck Mileage: 46613 Plate: Body Type: Conventional (A55852)
Year: 1999 Make...
JOHN DEERE CP 770 (A53084)
JOHN DEERE CP 770...
